iiyama ProLite T2236MSC-B2AG 21.5" 1920x1080 8ms VGA DVI HDMI Monit
Quicklinx: CW4CWS00 Mfr#: T2236MSC-B2AG
Diagonal Size: 21.5in
Max Resolution: 1920 x 1080
Response Time: 8ms
Speakers: Speaker(s)
Interfaces: DVI, HDMI, VGA (HD-15)
Hurry, only 2 left in stock!
£269.17 ex VAT
£323.00 inc VAT
With its Full HD resolution and accurate Projective Capacitive 10-point touch technology, the ProLite T2236MSC delivers seamless and accurate touch response. The AMVA panel technology guarantees high performance with excellent color reproduction and high contrast, making it an excellent choice for a vast array of demanding interactive applications. The anti-glare coating helps to avoid issues with reflections and external light sources affecting color reproduction, contrast and sharpness. Its flexible stand can be positioned at several angles creating a comfortable and ergonomic user experience.
iiyama ProLite T2236MSC-B2AG - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5" - touchscreen
Energy Class
Class B
Energy Consumption per Year
35 kWh
Power Consumption (On mode)
23.7 W
Touch-screen, USB 3.0 hub
Panel Type
A-MVA
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
3000:1 / 12000000:1 (dynamic)
Response Time
8 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, 7H Hard Coating
52.25 cm x 36.7 cm x 25.4 cm
5.8 kg
DDC-2B, VESA DPMS, TUV Bauart, CU
Display Type
Energy Class
Class B
35 kWh
23.7 W
Diagonal Size
21.5"
Viewable Size
21.5"
Built-in Devices
USB 3.0 hub
Panel Type
A-MVA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Brightness w/touchscreen
215 cd/m²
Contrast Ratio
Colour Support
Response Time
8 ms
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
+89 / -89
Vertical Viewing Angle
+89 / -89
Screen Coating
Backlight Technology
LED backlight
OSD Languages
Chinese (simplified), English, German, French, Italian, Portuguese, Russian, Spanish, Japanese
Eco-Mode, Advanced Contrast Ratio (ACR), HID Compliant, blue light reduction, i-Style Color
5.8 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
Input
Touch-screen - touchscreen
Movement Detection Technology
Projected capacitive
DVI-D , VGA , HDMI , Audio line-in , USB 3.0 upstream (Type B) , 4 x USB 3.0 downstream (Type A)
Mechanical
Tilt
Tilt Angle
-5/+90
VESA Mounting Interface
100 x 100 mm
1 x DVI cable , 1 x VGA cable , 1 x audio cable , 1 x SuperSpeed USB cable
Security Slot Type
Kensington security slot
23 Watt
Power Consumption Stand by
0.5 Watt
Included Software
Driver
Microsoft Windows 7 / 8 / 10
iiyama ProLite T2236MSC-B2AG 21.5 Bundle deal on iiyama ProLite T2236MSC-B2AG 21.5" 1920x1080 8ms VGA DVI HDMI Monit
£368.34
Response Time: 8ms
Interfaces: DVI
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: iiyama
Price Range Ex VAT: 150 - 300
