With its Full HD resolution and accurate Projective Capacitive 10-point touch technology, the ProLite T2236MSC delivers seamless and accurate touch response. The AMVA panel technology guarantees high performance with excellent color reproduction and high contrast, making it an excellent choice for a vast array of demanding interactive applications. The anti-glare coating helps to avoid issues with reflections and external light sources affecting color reproduction, contrast and sharpness. Its flexible stand can be positioned at several angles creating a comfortable and ergonomic user experience.
- iiyama ProLite T2236MSC-B2AG - LED monitor - Full HD (1080p) - 21.5"
- LED-backlit LCD monitor - 21.5" - touchscreen
- Energy Class
- Class B
- Energy Consumption per Year
- 35 kWh
- Power Consumption (On mode)
- 23.7 W
- Touch-screen, USB 3.0 hub
- Panel Type
- A-MVA
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.248 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 3000:1 / 12000000:1 (dynamic)
- Response Time
- 8 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, DVI-D, VGA
- Tilt
- Screen Coating
- Anti-glare, 7H Hard Coating
- Black
- 52.25 cm x 36.7 cm x 25.4 cm
- 5.8 kg
- DDC-2B, VESA DPMS, TUV Bauart, CU
- 3-year warranty
- Display Type
- Energy Class
- Class B
- 35 kWh
- Diagonal Size
- 21.5"
- Viewable Size
- 21.5"
- Built-in Devices
- USB 3.0 hub
- Panel Type
- A-MVA
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.248 mm
- Brightness
- 250 cd/m²
- Brightness w/touchscreen
- 215 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 8 ms
- Vertical Refresh Rate
- 56 - 75 Hz
- Horizontal Refresh Rate
- 30 - 80 kHz
- Horizontal Viewing Angle
- +89 / -89
- Vertical Viewing Angle
- +89 / -89
- Screen Coating
- Backlight Technology
- LED backlight
- OSD Languages
- Chinese (simplified), English, German, French, Italian, Portuguese, Russian, Spanish, Japanese
- Eco-Mode, Advanced Contrast Ratio (ACR), HID Compliant, blue light reduction, i-Style Color
- Black
- 5.8 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 2 Watt
Input
- Touch-screen - touchscreen
- Movement Detection Technology
- Projected capacitive
- DVI-D , VGA , HDMI , Audio line-in , USB 3.0 upstream (Type B) , 4 x USB 3.0 downstream (Type A)
Mechanical
- Tilt
- Tilt Angle
- -5/+90
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x DVI cable , 1 x VGA cable , 1 x audio cable , 1 x SuperSpeed USB cable
- Security Slot Type
- Kensington security slot
- Voltage Required
- AC 120/230 V (50/60 Hz)
- 23.7 W
- 23 Watt
- Power Consumption Stand by
- 0.5 Watt
- Included Software
- Driver
- OS Required
- Microsoft Windows 7 / 8 / 10
- Limited warranty - 3 years
