iiyama ProLite T2236MSC-B2 LED 22"  t/screen 1920x 1080 Full HD
Quicklinx: C7V5WS00 Mfr#: T2236MSC-B2
Diagonal Size: 22in
Max Resolution: 1920 x 1080
Response Time: 8ms
Speakers: Speaker(s)
Interfaces: DVI, HDMI, VGA (HD-15)
Hurry, only 3 left in stock!
£234.97 ex VAT
£281.96 inc VAT
With its Full HD (1920x1080) resolution and accurate Projective Capacitive 10 point touch technology, the ProLite T2236MSC delivers seamless and accurate touch response. The AMVA panel technology guarantees high performance with excellent color reproduction and high contrast, making it an excellent choice for a vast array of demanding interactive applications. The flexible stand can be positioned at several angles creating a comfortable and ergonomic user experience. The ProLite T2236MSC is the ideal screen for a great touch-experience.
  • Touch technology - capacitive
    This technology uses a sensor-grid of micro-fine wires integrated into the glass that covers the screen. Touch is detected because electrical characteristics of the sensor grid change when human finger is placed on the glass. Thanks to the glass overlay this technology is highly durable, and the touch function remains unaffected even if the glass is scratched.
  • AMVA
    AMVA technology offers higher contrast, darker blacks and much better viewing angles than standard TN technology. The screen will look good no matter what angle you look at it.
  • Scratch resistance
    Scratch resistance is essential for touch solutions used in public places and schools. This is achieved thanks to a glass overlay covering the screen. It guarantees high durability of the touch function and even more importantly the touch function remains unaffected even if the glass is scratched.
  • Blue light reducer
    Looking at a monitor screen for several hours per day, especially form a closer distance, causes eye fatigue. This effect is much stronger with computer screens than with TV equipment. One of the factors responsible for this phenomenon is the blue light emitted by the screen. Therefore reducing the amount of blue light ultimately allows the eyes to feel less tired while working long hours.
  • Speakers
    This LED monitor is equipped with two high quality stereo speakers.
iiyama ProLite T2236MSC-B2 - LED monitor - Full HD (1080p) - 22"
LED-backlit LCD monitor - 22" - touchscreen
Energy Class
Class B
Energy Consumption per Year
34 kWh
Power Consumption (On mode)
23 W
Touch-screen, USB 3.0 hub
Panel Type
A-MVA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
3000:1 / 12000000:1 (dynamic)
Response Time
8 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA
Display Position Adjustments
Tilt
Screen Coating
7H Hard Coating
52.25 cm x 25.4 cm x 36.7 cm
5.8 kg
DDC-2B, VESA DPMS, TUV Bauart
3-year warranty
Display Type
Energy Class
Class B
34 kWh
23 W
Diagonal Size
22"
Viewable Size
21.5"
Built-in Devices
USB 3.0 hub
Panel Type
A-MVA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Brightness w/touchscreen
213 cd/m²
Contrast Ratio
Colour Support
Response Time
8 ms (grey-to-grey)
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
+89 / -89
Vertical Viewing Angle
+89 / -89
Screen Coating
7H Hard Coating
Backlight Technology
LED backlight
Controls & Adjustments
Volume, brightness, contrast, H/V position, input select, colour temperature, phase, aspect control, blue reduction
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Russian, Spanish, Japanese
Eco-Mode, Advanced Contrast Ratio (ACR), 10-point multi-touch, blue light reduction
52.25 cm x 25.4 cm x 36.7 cm - with stand
5.8 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
Input
Touch-screen - touchscreen
Movement Detection Technology
Projected capacitive
VGA , DVI-D , HDMI , Headphones , USB 3.0 upstream (Type B) , 4 x USB 3.0 downstream (Type A)
Mechanical
Tilt
Tilt Angle
-5/+90
VESA Mounting Interface
100 x 100 mm
1 x VGA cable - VGA to VGA , 1 x DVI cable - DVI-D to DVI-D , 1 x audio cable , 1 x SuperSpeed USB cable - USB Type A to B
Security Slot Type
Kensington security slot
23 Watt
Power Consumption Stand by
0.5 Watt
On / Off Switch
No
Included Software
Driver
Microsoft Windows 7 / Windows 8
Dimensions & Weight Details
With stand - width: 52.25 cm - depth: 25.4 cm - height: 36.7 cm - weight: 5.8 kg , Without stand - width: 52.25 cm - depth: 5.7 cm - height: 31.6 cm
Limited warranty - 3 years
5 °C
35 °C
20 - 80% (non-condensing)
iiyama ProLite T2236MSC-B2 LED 22 Bundle deal on iiyama ProLite T2236MSC-B2 LED 22" t/screen 1920x 1080 Full HD
£334.14
C7V5 C2G 2m DVI-D™ M/M Dual Link Digital Video Cable In Stock £9.20
C7V5 C2G USB 3.0 to Gigabit Ethernet Network Adapter In Stock £23.08
Diagonal Size: 22in
Response Time: 8ms
Interfaces: DVI
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: iiyama
Price Range Ex VAT: 150 - 300
