iiyama ProLite T2235MSC-B1 LED Monitor 22" Touchscreen
Quicklinx: C4P3WS00 Mfr#: T2235MSC-B1
Diagonal Size: 22in
Max Resolution: 1920 x 1080
Response Time: 6ms
Speakers: Speaker(s)
Interfaces: DisplayPort, DVI, VGA (HD-15)
Hurry, only 2 left in stock!
£255.17 ex VAT
£306.20 inc VAT
With 1920 x 1080 Full HD resolution and Projective Capacitive 10 point touch technology, the ProLite T2235MSC delivers seamless and accurate touch response. Featuring VA LED-backlit LCD screen technology, it offers exceptional color performance and wide viewing angles, making it an excellent choice for a vast array of demanding interactive applications. Users can benefit from its hinged stand allowing the monitor to lay down completely flat for use as a giant tablet. The T2235MSC comes equipped with several video inputs and stereo speakers delivering good quality sound. An ideal screen for Interactive Digital Signage, InStore Retail, Gaming and Interactive Presentations purposes.
  • Touch technology - capacitive
    This technology uses a sensor-grid of micro-fine wires integrated into the glass that covers the screen. Touch is detected because electrical characteristics of the sensor grid change when human finger is placed on the glass. Thanks to the glass overlay this technology is highly durable, and the touch function remains unaffected even if the glass is scratched. It offers perfect picture performance and will work with human finger (gloved or not) and magnetic ball.
  • Blue light reduction
    As we all know looking at a monitor screen for several hours per day, especially form a closer distance, causes eye fatigue. This effect is much stronger with computer screens than with TV equipment. One of the factors responsible for this phenomenon is the blue light emitted by the screen. Therefore reducing the amount of blue light ultimately allows eyes to feel less tired while working long hours with a computer screen. They achieved it by adjusting the monitor's brightness and color temperature through a feature called "Blue light reduction" easily accessible through the monitor's OSD menu.
  • Scratch resistance
    Scratch resistance is essential for touch solutions used in public places and schools. This is achieved thanks to a glass overlay covering the screen. It guarantees high durability of the touch function and even more importantly the touch function remains unaffected even if the glass is scratched.
iiyama ProLite T2235MSC-B1 - LED monitor - Full HD (1080p) - 22"
LED-backlit LCD monitor - 22" - touchscreen
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.248 mm
Contrast Ratio
3000:1 / 12000000:1 (dynamic)
Response Time
6 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA, DisplayPort
Display Position Adjustments
Tilt
52.25 cm x 4.9 cm x 32.05 cm
5 kg
DDC-2B, VESA DPMS, TUV Bauart, VCCI Class B, CU-EAC
Display Type
Diagonal Size
22"
Viewable Size
21.5"
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness w/touchscreen
225 cd/m²
Contrast Ratio
Colour Support
Response Time
6 ms
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
176
Vertical Viewing Angle
176
Backlight Technology
LED backlight
Controls & Adjustments
Mute, volume, brightness, contrast, H/V position, sharpness, input select, phase, clock, blue reduction
OSD Languages
Czech, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Polish, Russian, Dutch, Japanese
Eco-Mode, X-Res Technology, 10-point multi-touch
5 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
Input
Touchscreen
VGA , DVI-D , DisplayPort , USB , Audio line-in
Mechanical
Tilt
Tilt Angle
-15/+70
VESA Mounting Interface
100 x 100 mm
1 x audio cable , 1 x DVI cable , 1 x USB cable
Security Slot Type
Kensington security slot
21 Watt
Power Consumption Stand by
0.5 Watt
Linux, Microsoft Windows Vista / 7 / 8, Windows 10
iiyama ProLite T2235MSC-B1 LED Monitor 22 Bundle deal on iiyama ProLite T2235MSC-B1 LED Monitor 22" Touchscreen
£354.93
C4P3 C2G 2m USB 2.0 A/B Cable - Black In Stock £2.00
C4P3 C2G 5m USB 2.0 A/B Cable - Black In Stock £5.14
C4P3 C2G 5m USB 2.0 A Male to A Female Active Extension Cable In Stock £12.94
C4P3 C2G 12m USB 2.0 A/A Active Extension Cable In Stock £16.96
C4P3 C2G USB Superbooster Extender Kit In Stock £38.72
C4P3 C2G Trulink® USB to Gigabit Ethernet Adapter In Stock £23.94
C4P3 C2G USB to HDMI Adapter with Audio Up To 1080p In Stock £42.30
Diagonal Size: 22in
Response Time: 6ms
Interfaces: DVI
Interfaces: VGA (HD-15)
Brand: iiyama
Price Range Ex VAT: 150 - 300
