iiyama ProLite T2234MSC-B6X 22" 1920x1080 8ms VGA HDMI DisplayPort Touchscreen IPS LED Monitor
Quicklinx: FJ1MWS00 Mfr#: T2234MSC-B6X
Diagonal Size: 21.5in
Max Resolution: 1920 x 1080
Response Time: 8ms
Speakers: Speaker(s)
Interfaces: DisplayPort, HDMI, VGA (HD-15)
£408.03 ex VAT
£489.63 inc VAT
Featuring IPS LCD screen technology, it offers exceptional color performance and wide viewing angles, making it a perfect interactive display for interactive digital signage. In addition to the superb image quality, the screen is suitable for demanding environments.
iiyama ProLite T2234MSC-B6X - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5" - touchscreen
Energy Class
Class B
Energy Consumption per Year
31 kWh
Power Consumption (On mode)
21.4 W
Touch-screen
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.247 mm
Brightness
350 cd/m²
Contrast Ratio
500:1
Response Time
8 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Tilt
Screen Coating
7H Hard Coating
51.75 cm x 21.9 cm x 35.15 cm
4.4 kg
VCCI, DDC-2B, VESA DPMS, cULus, TUV Bauart, IP65, CU
Display Type
Energy Class
Class B
31 kWh
21.4 W
Diagonal Size
21.5"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.247 mm
Brightness
350 cd/m²
Brightness w/touchscreen
305 cd/m²
Contrast Ratio
500:1
Colour Support
Response Time
8 ms
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 84 kHz
Horizontal Viewing Angle
+89 / -89
Vertical Viewing Angle
+89 / -89
Screen Coating
7H Hard Coating
Backlight Technology
LED backlight
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Spanish, Japanese
HDCP, scratch-resistant, Projected Capacitive Touch (P-CAP) technology
4.4 kg
Audio
Speakers - stereo
Output Power / Channel
3 Watt
Input
Touch-screen - touchscreen
Movement Detection Technology
Projected capacitive
VGA , DisplayPort , USB , HDMI
Mechanical
Tilt
Tilt Angle
-5/+90
VESA Mounting Interface
100 x 100 mm
1 x HDMI cable - 1.8 m , 1 x DisplayPort cable - 1.8 m , 1 x USB cable - 1.8 m , 1 x audio cable - 1.8 m
21 Watt
Power Consumption Stand by
1 Watt
Power Consumption (Off Mode)
1 Watt
Included Software
Driver
iiyama ProLite T2234MSC-B6X 22 Bundle deal on iiyama ProLite T2234MSC-B6X 22" 1920x1080 8ms VGA HDMI DisplayPort Touchscreen IPS LED Monitor
£507.20
Response Time: 8ms
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: iiyama
Price Range Ex VAT: 300 - 500
