iiyama ProLite T2234MSC-B5X 22" 1920x1080 8ms VGA HDMI DisplayPort Touchscreen LED Monitor
Quicklinx: DVQVWS00 Mfr#: T2234MSC-B5X
ProLite T2234MSC uses Projective Capacitive Touch technology, built into an eye catching bezel with edge to edge glass. Featuring IPS LCD screen technology, it offers exceptional color performance and wide viewing angles, making it a perfect interactive display for interactive digital signage. In addition to the superb image quality, the screen is suitable for demanding environments. It is dust and water resistant from the front. The ProLite T2234MSC is the ideal solution for interactive digital signage, instore retail, kiosks, gaming and interactive presentations.
  • Touch technology
    This technology uses a sensor-grid of micro-fine wires integrated into the glass that covers the screen. Touch is detected because electrical characteristics of the sensor grid change when human finger is placed on the glass. Thanks to the glass overlay this technology is highly durable, and the touch function remains unaffected even if the glass is scratched. It offers perfect picture performance and will work with human finger (also latex gloved) and stylus-pen.
  • IPS
    IPS technology offers higher contrast, darker blacks and much better viewing angles than standard TN technology. The screen will look good no matter what angle you look at it.
  • Scratch resistance
    Scratch resistance is essential for touch solutions used in public places and schools. This is achieved thanks to a glass overlay covering the screen. It guarantees high durability of the touch function and even more importantly the touch function remains unaffected even if the glass is scratched.
iiyama ProLite T2234MSC-B5X - LED monitor - Full HD (1080p) - 22"
LED-backlit LCD monitor - 22" - touchscreen
Energy Class
Class B
Energy Consumption per Year
31 kWh
Power Consumption (On mode)
21 W
Touch-screen
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.247 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
8 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Tilt
Screen Coating
7H Hard Coating
51.75 cm x 21.9 cm x 35.15 cm
7.2 kg
VCCI, DDC-2B, VESA DPMS, cULus, TUV Bauart, IP65, CU
Display Type
Energy Class
Class B
31 kWh
Diagonal Size
22"
Viewable Size
21.5"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.247 mm
Brightness
250 cd/m²
Brightness w/touchscreen
225 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
8 ms
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
31.5 - 82.3 kHz
Horizontal Viewing Angle
+89 / -89
Vertical Viewing Angle
+89 / -89
Screen Coating
7H Hard Coating
Backlight Technology
LED backlight
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Spanish, Japanese
HDCP, scratch-resistant, Projected Capacitive Touch (P-CAP) technology
51.75 cm x 21.9 cm x 35.15 cm - with stand
7.2 kg
Audio
Speakers - stereo
Output Power / Channel
3 Watt
Input
Touch-screen - touchscreen
Movement Detection Technology
Projected capacitive
VGA , DisplayPort , USB , HDMI
Mechanical
Tilt
Tilt Angle
-5/+90
VESA Mounting Interface
100 x 100 mm
1 x HDMI cable , 1 x DisplayPort cable , 1 x USB cable , 1 x audio cable
DC 12 V
21 W
21 Watt
Power Consumption (Typical)
21 Watt
Included Software
Driver
Microsoft Windows 95/98, Microsoft Windows CE, Linux, Apple MacOS X, Microsoft Windows Vista / XP, Microsoft Windows 7 / 8 / 10
