Product
iiyama ProLite T2234MC-B1X 22" 1920x1080 5ms VGA DVI USB Touchscreen IPS LED Monitor
Quicklinx: B1JVWS00 Mfr#: T2234MC-B1X
ProLite T2234MC uses Projective Capacitive Touch Technology, built into an eye catching bezel with Edge to Edge glass. Featuring IPS LCD Screen technology, it offers exceptional color performance and wide viewing angles, making it a perfect interactive display for Interactive Digital Signage. In addition to the superb image quality, the screen comes with an IP54 Rating, making it dust and water resistant. It comes with a rugged bezel making it suitable for demanding environments. The screen also features a vast array of inputs including DVI as well as USB for the Touch sensor itself, and a High Definition 1920 x 1080 Resolution. The ProLite T2234MC is the ideal solution for Interactive Digital Signage, Instore Retail, Kiosks, Gaming and Interactive Presentations.
iiyama ProLite T2234MC-B1X - LED monitor - Full HD (1080p) - 22"
LED-backlit LCD monitor - 22" - touchscreen
Touch-screen
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.247 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
8 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Display Position Adjustments
Tilt
Screen Coating
7H Hard Coating
51.75 cm x 21.9 cm x 35.17 cm
7.2 kg
VCCI, DDC-2B, IP54, TUV Bauart
Display Type
Diagonal Size
22"
Viewable Size
21.5"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.247 mm
Brightness
250 cd/m²
Brightness w/touchscreen
225 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
8 ms (grey-to-grey)
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
31.5 - 82.3 kHz
Horizontal Viewing Angle
+89 / -89
Vertical Viewing Angle
+89 / -89
Screen Coating
7H Hard Coating
Backlight Technology
LED backlight
Controls & Adjustments
Brightness, contrast, H/V position, input select, colour temperature, phase
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Spanish, Japanese
10-point multi-touch, Projected Capacitive Touch (PCT) technology
51.75 cm x 21.9 cm x 35.17 cm - with stand
7.2 kg
Input
Touch-screen - touchscreen
Movement Detection Technology
Projected capacitive
DVI-D , VGA , USB
Mechanical
Tilt
Tilt Angle
-5/+90
Flat Panel Mount Interface
100 x 100 mm
1 x DVI cable , 1 x VGA cable , 1 x USB cable
Security Slot Type
Kensington security slot
Power Supply
External
40 Watt
Power Consumption Stand by
3 Watt
Included Software
Driver
Dimensions & Weight Details
With stand - width: 51.75 cm - depth: 21.9 cm - height: 35.17 cm - weight: 7.2 kg , Without stand - width: 51.75 cm - depth: 4.6 cm - height: 31.35 cm
5 °C
35 °C
20 - 80% (non-condensing)
B1JV C2G 2m USB 2.0 A/B Cable - Black In Stock £3.10
B1JV C2G 5m USB 2.0 A/B Cable - Black In Stock £4.51
B1JV C2G 5m USB 2.0 A Male to A Female Active Extension Cable In Stock £12.76
B1JV C2G 4-Port USB 2.0 Aluminum Hub In Stock £19.32
B1JV C2G 12m USB 2.0 A/A Active Extension Cable In Stock £16.73
B1JV C2G USB Superbooster Extender Kit In Stock £37.81
B1JV C2G Trulink® USB to Gigabit Ethernet Adapter In Stock £23.38
B1JV C2G USB to HDMI Adapter with Audio Up To 1080p In Stock £42.30
