The ProLite T1932MSC-W5AG multi-touch screen is based on projective capacitive technology which thanks to a glass overlay covering the screen guarantees high durability, scratch-resistance and perfect picture performance. The IPS matrix guarantees high performance with accurate and consistent color reproduction, and wide viewing angles.
- iiyama ProLite T1932MSC-W5AG - LED monitor - 19"
- LED-backlit LCD monitor - 19" - touchscreen
- Energy Class
- Class E
- Energy Consumption per Year
- 33 kWh
- Power Consumption (On mode)
- 14.2 W
- Touch-screen
- Panel Type
- IPS
- Aspect Ratio
- 5:4
- Native Resolution
- 1280 x 1024
- Pixel Pitch
- 0.2928 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 14 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, VGA, DisplayPort
- Tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V (50/60 Hz)
- White
- Image Colour Disclaimer
- The displayed product image may be a different colour
- 43.2 cm x 21.9 cm x 39.1 cm
- 6.9 kg
- VCCI, DDC-2B, CB, cULus, IP54, TUV Bauart, CU
- Display Type
- Energy Class
- Class E
- 33 kWh
- Diagonal Size
- 19"
- Panel Type
- IPS
- Aspect Ratio
- 5:4
- Native Resolution
- 1280 x 1024
- Pixel Pitch
- 0.2928 mm
- Brightness
- 250 cd/m²
- Brightness w/touchscreen
- 215 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Response Time
- 14 ms
- Vertical Refresh Rate
- 50 - 75 Hz
- Horizontal Refresh Rate
- 31 - 80 KHz
- Horizontal Viewing Angle
- +89 / -89
- Vertical Viewing Angle
- +89 / -89
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- OSD Languages
- English, German, French, Italian, Spanish, Japanese, Chinese
- Cable management cover, HDCP, edge-to-edge glass, scratch-resistant
- White
- 6.9 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 1 Watt
Input
- Touch-screen - touchscreen
- Movement Detection Technology
- Projected capacitive
- VGA , HDMI , DisplayPort , Audio line-in , USB
Mechanical
- Tilt
- Tilt Angle
- -5/+90
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), IP54 protection, 85% light transmittance
- Cables Included
- 1 x DisplayPort cable , 1 x HDMI cable , 1 x audio cable , 1 x SuperSpeed USB cable
- Security Slot Type
- Kensington security slot
- Input Voltage
- 14.2 W
- Power Consumption SDR (On mode)
- 14.2 kWh/1000h
- Power Consumption (Typical)
- 25 Watt
- 2 Watt
- Included Software
- Drivers & Utilities
