iiyama ProLite T1932MSC-B5X 19" 1280x1024 14ms HMDI VGA DP LED Monitor
Quicklinx: DRGPWS00 Mfr#: T1932MSC-B5X
Diagonal Size: 19in
Max Resolution: 1280 x 1024
Response Time: 14ms
Speakers: Speaker(s)
Interfaces: DisplayPort, HDMI, VGA (HD-15)
Hurry, only 2 left in stock!
£405.69 ex VAT
£486.82 inc VAT
The ProLite T1932MSC-B2X multi touch screen is based on projective capacitive technology which thanks to a glass overlay covering the screen guarantees high durability, scratch-resistance and perfect picture performance. The IPS matrix guarantees high performance with accurate and consistent color reproduction, and wide viewing angles.
iiyama ProLite T1932MSC-B5X - LED monitor - 19"
LED-backlit LCD monitor - 19" - touchscreen
Energy Class
Class B
Touch-screen
Panel Type
IPS
Aspect Ratio
5:4
Native Resolution
1280 x 1024
Pixel Pitch
0.2928 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
14 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Tilt
43.2 cm x 21.9 cm x 39.1 cm
6.9 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, DDC-2B, CB, cULus, IP54, TUV Bauart, EAC, CU
Display Type
Energy Class
Class B
Diagonal Size
19"
Panel Type
IPS
Aspect Ratio
5:4
Native Resolution
1280 x 1024
Pixel Pitch
0.2928 mm
Brightness
250 cd/m²
Brightness w/touchscreen
225 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
14 ms
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
31- 80 kHz
Horizontal Viewing Angle
+89 / -89
Vertical Viewing Angle
+89 / -89
Backlight Technology
LED backlight
OSD Languages
English, German, French, Italian, Spanish, Japanese, Chinese
Cable management cover, HDCP, edge-to-edge glass, scratch-resistant
6.9 kg
Audio
Speakers - stereo
Output Power / Channel
1 Watt
Input
Touch-screen - touchscreen
Movement Detection Technology
Projected capacitive
VGA , HDMI , DisplayPort , Audio line-in , USB
Mechanical
Tilt
Tilt Angle
-5/+90
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), 90% light transmittance
1 x DisplayPort cable - 1.8 m , 1 x HDMI cable - 1.8 m , 1 x audio cable - 1.8 m , 1 x SuperSpeed USB cable - 1.8 m
Security Slot Type
Kensington security slot
25 Watt
Power Consumption Stand by
2 Watt
Included Software
Drivers & Utilities
ENERGY STAR Certified
iiyama ProLite T1932MSC-B5X 19 Bundle deal on iiyama ProLite T1932MSC-B5X 19" 1280x1024 14ms HMDI VGA DP LED Monitor
£505.45
Diagonal Size: 19in
Response Time: 14ms
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: iiyama
Price Range Ex VAT: 300 - 500
