iiyama ProLite T1932MSC-B2X 17" 1280x1024 5ms VGA DVI USB Touchscreen Monitor
Quicklinx: B1JTWS00 Mfr#: T1932MSC-B2X
The ProLite T1932MSC-B2X 19" multi touch screen is based on projective capacitive technology which thanks to a glass overlay covering the screen guarantees high durability, scratch-resistance and perfect picture performance. The IPS matrix guarantees high performance with accurate and consistent color reproduction, and wide viewing angles. The touch function remains unaffected even if the glass is scratched. A solid and steady base supports the touch screen with an adjustable stand offering full 90 degree positioning angles. In addition the edge-to-edge glass design creates an eye-catching finish with high light transmission guaranteeing perfect picture clarity and brilliant colors.
iiyama ProLite T1932MSC-B2X - LED monitor - 19"
LED-backlit LCD monitor - 19" - touchscreen
Touch-screen
Panel Type
IPS
Aspect Ratio
5:4
Native Resolution
1280 x 1024
Pixel Pitch
0.294 mm
Brightness
225 cd/m²
Contrast Ratio
1000:1
Response Time
14 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
Tilt
Screen Coating
7H Hard Coating
43.2 cm x 21.9 cm x 39.1 cm
6.9 kg
VCCI, VESA DPMS, CB, cULus, IP54, TUV Bauart
Display Type
Diagonal Size
19"
Panel Type
IPS
Aspect Ratio
5:4
Native Resolution
1280 x 1024
Pixel Pitch
0.294 mm
Brightness
225 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
14 ms
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
31.4 - 80 kHz
Horizontal Viewing Angle
+89 / -89
Vertical Viewing Angle
+89 / -89
Screen Coating
7H Hard Coating
Backlight Technology
LED backlight
Controls & Adjustments
Mute, volume, brightness, contrast, H/V position, input select, colour temperature, phase, H-size
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Spanish, Japanese
Edge-to-edge glass, scratch-resistant
6.9 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
1 Watt
Input
Touch-screen - touchscreen
Movement Detection Technology
Projected capacitive
VGA , DVI-D , USB , Audio line-in
Mechanical
Tilt
Tilt Angle
-5/+90
VESA Mounting Interface
100 x 100 mm
1 x VGA cable - VGA to VGA , 1 x DVI cable - DVI-D to DVI-D , 1 x audio cable , 1 x USB cable
Security Slot Type
Kensington security slot
Power Supply
Internal
20 Watt
Power Consumption Stand by
2 Watt
Included Software
Drivers & Utilities
B1JT C2G 2m USB 2.0 A/B Cable - Black In Stock £3.90
B1JT C2G 5m USB 2.0 A/B Cable - Black In Stock £5.05
B1JT C2G 5m USB 2.0 A Male to A Female Active Extension Cable In Stock £12.83
B1JT C2G 12m USB 2.0 A/A Active Extension Cable In Stock £16.66
B1JT C2G USB Superbooster Extender Kit In Stock £37.61
B1JT C2G Trulink® USB to Gigabit Ethernet Adapter In Stock £23.49
B1JT C2G USB to HDMI Adapter with Audio Up To 1080p In Stock £42.30
