iiyama ProLite T1931SR-W1 19" 1280x1024 5ms DVI USB Touchscreen LCD Monitor
Quicklinx: B5C7WS00 Mfr#: T1931SR-W1
ProLite 1931SR is based on the 5 Wire Resistive technology. Price/performance ratio is ideal for the budget conscious user while quality and specification is certainly not compromised. The display inputs include both analog and digital (DVI) with touchscreen connectivity via either USB or RS-232 which offers greater than typical flexibility. A solid and steady base supports the TouchScreen with an adjustable stand offering full 90 degree angles. Extensive touch utilities allow for 4 point calibration and either 9/25 point linearization.
iiyama ProLite T1931SR-W1 - LCD monitor - 19"
LCD monitor - 19" - touchscreen
Touch-screen, stereo speakers
Panel Type
TN
Aspect Ratio
5:4
Native Resolution
1280 x 1024
Pixel Pitch
0.294 mm
Brightness
200 cd/m²
Contrast Ratio
900:1
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
Tilt
White
43.1 cm x 39.1 cm x 21.8 cm
6.5 kg
Plug and Play, FCC Class B certified, UL, TUV, VCCI Class B ITE, cUL
Display Type
LCD monitor / TFT active matrix
Diagonal Size
19"
Built-in Devices
Stereo speakers
Panel Type
TN
Aspect Ratio
5:4
Native Resolution
1280 x 1024
Pixel Pitch
0.294 mm
Brightness
200 cd/m²
Contrast Ratio
900:1
Colour Support
Response Time
5 ms
Vertical Refresh Rate
75 Hz
Horizontal Refresh Rate
80 kHz
Horizontal Viewing Angle
+85 / -80
Vertical Viewing Angle
+85 / -80
Controls & Adjustments
Volume, brightness, contrast, H/V position, input select, colour temperature, phase, clock
OSD Languages
English, German, French, Italian, Spanish, Japanese, Chinese
White
6.5 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
1 Watt
Input
Touch-screen - touchscreen
Movement Detection Technology
Resistive
Serial , DVI-D , VGA , Audio line-in , USB
Mechanical
Tilt
Tilt Angle
95
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), wall mountable
1 x VGA cable , 1 x DVI cable , 1 x audio cable , 1 x serial cable , 1 x USB cable
Security Slot Type
Kensington security slot
Power Supply
Internal
25 Watt
Power Consumption Stand by / Sleep
2 Watt
Included Software
Drivers & Utilities
Apple MacOS, Microsoft Windows 95/98/ME/2000/XP
B5C7 C2G 2m USB 2.0 A/B Cable - Black In Stock £3.83
B5C7 C2G 5m USB 2.0 A/B Cable - Black In Stock £5.13
B5C7 C2G 5m USB 2.0 A Male to A Female Active Extension Cable In Stock £13.19
B5C7 C2G 12m USB 2.0 A/A Active Extension Cable In Stock £17.16
