iiyama ProLite T1931SAW-B5 19" 1280x1024 5ms VGA HDMI DisplayPort Touchscreen LED Monitor
Quicklinx: FJ1GWS00 Mfr#: T1931SAW-B5
Diagonal Size: 19in
Max Resolution: 1280 x 1024
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: DisplayPort, HDMI, VGA (HD-15)
£358.41 ex VAT
£430.09 inc VAT
The ProLite T1931SAW-B5 uses highly accurate Surface Acoustic Wave touch technology (SAW) with a pure-glass scratch resistive front, offering superior image clarity and screen durability. The screen can be touched with a soft stylus, finger or gloved hand making it suitable for a number of applications, and the solid but flexible stand ensures resilience in the most demanding environments. Menu buttons are located on the side of the screen which can be locked to prevent tampering, and include a handy function to deactivate the touchscreen for cleaning. The iiyama Prolite T1931SAW-B5 touchscreen is ideal for a wide range of applications including Point of Sale, kiosks, hospitality and entertainment, control rooms, education, training and many others.
  • Surface Acoustic Wave touch technology
    Surface acoustic wave uses ultrasonic waves that pass over the panel. When the panel is touched, a portion of the wave is absorbed and a touch event is registered. Because the screen is covered with a glass layer this technology offers great picture performance (high contrast and color accuracy). It is also scratch-resistant technology and therefore ideal for use in public places or schools. Even if the screen is scratched, the touch function remains unaffected.
  • Scratch resistance
    Scratch resistance is essential for touch solutions used in public places and schools. This is achieved thanks to a glass overlay covering the screen. It guarantees high durability of the touch function and even more importantly the touch function remains unaffected even if the glass is scratched.
  • IP54 rated
    The IP code classifies how resistant a device is to foreign objects and moisture. IP54 means that the monitor will operate in dusty conditions, and will resist splashing water.
  • Integrated speakers
    This LED monitor is equipped with two high-quality stereo speakers.
iiyama ProLite T1931SAW-B5 - LED monitor - 19"
LED-backlit LCD monitor - 19" - touchscreen
Energy Class
Class E
Power Consumption (On mode)
14.7 W
Touch-screen
Panel Type
TN
Aspect Ratio
5:4
Native Resolution
1280 x 1024
Pixel Pitch
0.294 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Tilt
Voltage
Matte black
43.2 cm x 21.8 cm x 39 cm
6.6 kg
Plug and Play, VCCI, GOST, DDC-2B, CB, IP54, TUV Bauart
Display Type
Energy Class
Class E
Diagonal Size
19"
Panel Type
TN
Aspect Ratio
5:4
Native Resolution
1280 x 1024
Pixel Pitch
0.294 mm
Brightness
250 cd/m²
Brightness w/touchscreen
230 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
5 ms
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
31 - 80 KHz
Horizontal Viewing Angle
+85 / -85
Vertical Viewing Angle
+80 / -80
Backlight Technology
LED backlight
OSD Languages
English, German, French, Italian, Spanish, Japanese, Chinese
Cable management cover, HDCP, OSD lock, scratch-resistant
Matte black
43.2 cm x 21.8 cm x 39 cm - with stand
6.6 kg
Audio
Speakers - stereo
Output Power / Channel
1 Watt
Input
Touch-screen - touchscreen
Movement Detection Technology
VGA , DisplayPort , HDMI , USB , Audio line-in
Mechanical
Tilt
Tilt Angle
-5/+90
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), IP54 protection
1 x USB cable , 1 x HDMI cable , 1 x audio cable , 1 x DisplayPort cable
Security Slot Type
Kensington security slot
Input Voltage
14.7 W
14.7 kWh/1000h
Power Consumption (Typical)
20 Watt
Power Consumption Stand by
3 Watt
Included Software
Drivers & Utilities
Diagonal Size: 19in
Response Time: 5ms
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: iiyama
