iiyama ProLite T1732MSC-W1X 17" 1280x1024 5ms VGA DVI USB Touchscreen Monitor
Quicklinx: B1JSWS00 Mfr#: T1732MSC-W1X
The ProLite T1732MSC 17" multi-touch screen is based on projected capacitive technology which thanks to a glass overlay covering the screen guarantees high durability, scratch-resistance and perfect picture performance. The touch function remains unaffected even if the glass is scratched. A solid and steady base supports the touchscreen with an adjustable stand offering full 90-degree positioning angles. Menu buttons are located on the side of the screen which can be locked to prevent tampering and includes a handy function to deactivate the touchscreen for cleaning. In addition the edge-to-edge glass design creates an eye-catching finish with high light transmission guaranteeing perfect picture clarity and brilliant colors.
  • Touch technology - capacitive
    This technology uses a sensor-grid of micro-fine wires integrated into the glass that covers the screen. Touch is detected because electrical characteristics of the sensor grid change when human finger is placed on the glass. Thanks to the glass overlay this technology is highly durable, and the touch function remains unaffected even if the glass is scratched.
  • Scratch resistance
    Scratch resistance is essential for touch solutions used in public places and schools. This is achieved thanks to a glass overlay covering the screen. It guarantees high durability of the touch function and even more importantly the touch function remains unaffected even if the glass is scratched.
  • LED-backlit
    A typical CCFL LCD uses four backlight lamps. Using LED diodes considerably lowers the power consumption and reduces the CO2 emission into the environment making this LCD a true ECO-friendly product.
  • IP54
    The IP code classifies how resistant a device is to foreign objects and moisture. IP54 means that the monitor will operate in dusty conditions, and will resist splashing water.
iiyama ProLite T1732MSC-W1X - LED monitor - 17"
LED-backlit LCD monitor - 17" - touchscreen
Touch-screen
Panel Type
TN
Aspect Ratio
5:4
Native Resolution
1280 x 1024
Pixel Pitch
0.264 mm
Brightness
225 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
Tilt
Screen Coating
7H Hard Coating
Voltage
Black, white
38.7 cm x 20.2 cm x 34.2 cm
5.6 kg
VCCI, VESA DPMS, CB, GOST-R, IP54, TUV Bauart
Display Type
Diagonal Size
17"
Panel Type
TN
Aspect Ratio
5:4
Native Resolution
1280 x 1024
Pixel Pitch
0.264 mm
Brightness
225 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
5 ms
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
31.4 - 80 kHz
Horizontal Viewing Angle
+80 / -80
Vertical Viewing Angle
+80 / -80
Screen Coating
7H Hard Coating
Backlight Technology
LED backlight
Controls & Adjustments
Mute, volume, brightness, contrast, H/V position, input select, colour temperature, phase, H-size
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Spanish, Japanese
10-point multi-touch
Black, white
5.6 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
1 Watt
Input
Touch-screen - touchscreen
Movement Detection Technology
Projected capacitive
VGA , DVI-D , USB , Audio line-in
Mechanical
Tilt
Tilt Angle
-5/+90
VESA Mounting Interface
100 x 100 mm
1 x VGA cable , 1 x DVI cable - DVI-D to DVI-D , 1 x audio cable , 1 x USB cable
Security Slot Type
Kensington security slot
Power Supply
Internal
Input Voltage
Power Consumption (Typical)
25 Watt
Power Consumption Stand by
2 Watt
Included Software
Drivers & Utilities
