iiyama ProLite T1732MSC-B5X 17" 1280x1024 LED Monitor
Quicklinx: DKJJWS00 Mfr#: T1732MSC-B5X
Diagonal Size: 17in
Max Resolution: 1280 x 1024
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: DisplayPort, HDMI, VGA (HD-15)
£370.41 ex VAT
£444.49 inc VAT
Marketing description is not available.
iiyama ProLite T1732MSC-B5X - LED monitor - 17"
LED-backlit LCD monitor - 17" - touchscreen
Energy Class
Class B
Energy Consumption per Year
27 kWh
Power Consumption (On mode)
19 W
Touch-screen
Panel Type
TN
Aspect Ratio
5:4
Native Resolution
1280 x 1024
Pixel Pitch
0.264 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
38.7 cm x 20.2 cm x 34.2 cm
5.6 kg
Plug and Play, VCCI, GOST, DDC-2B, CB, IP54, TUV Bauart
Display Type
Energy Class
Class B
27 kWh
19 W
Diagonal Size
17"
Viewable Size
17"
Panel Type
TN
Aspect Ratio
5:4
Native Resolution
1280 x 1024
Pixel Pitch
0.264 mm
Brightness
250 cd/m²
Brightness w/touchscreen
225 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
5 ms
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
31.4 - 80 kHz
Horizontal Viewing Angle
+85 / -85
Vertical Viewing Angle
+80 / -80
Screen Coating
Anti-glare
Backlight Technology
LED backlight
OSD Languages
English, German, French, Italian, Spanish, Japanese, Chinese
Cable management cover, HDCP, edge-to-edge glass, OSD lock, scratch-resistant, glove touch mode
38.7 cm x 20.2 cm x 34.2 cm - with stand
5.6 kg
Audio
Speakers - stereo
Output Power / Channel
1 Watt
Input
Touch-screen - touchscreen
Movement Detection Technology
Projected capacitive
VGA , HDMI , DisplayPort , USB , Audio line-in
Mechanical
Tilt
Tilt Angle
-5/+90
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), 90% light transmittance
USB cable , HDMI cable , Audio cable , DisplayPort cable
Security Slot Type
Kensington security slot
25 Watt
Power Consumption Stand by
2 Watt
Included Software
Drivers & Utilities
iiyama ProLite T1732MSC-B5X 17 Bundle deal on iiyama ProLite T1732MSC-B5X 17" 1280x1024 LED Monitor
£461.95
Diagonal Size: 17in
Response Time: 5ms
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: iiyama
Price Range Ex VAT: 300 - 500
