- iiyama ProLite T1732MSC-B5X - LED monitor - 17"
- LED-backlit LCD monitor - 17" - touchscreen
- Energy Class
- Class B
- Energy Consumption per Year
- 27 kWh
- Power Consumption (On mode)
- 19 W
- Touch-screen
- Panel Type
- TN
- Aspect Ratio
- 5:4
- Native Resolution
- 1280 x 1024
- Pixel Pitch
- 0.264 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, VGA, DisplayPort
- Tilt
- Screen Coating
- Anti-glare
- Black
- 38.7 cm x 20.2 cm x 34.2 cm
- 5.6 kg
- Plug and Play, VCCI, GOST, DDC-2B, CB, IP54, TUV Bauart
- Display Type
- Energy Class
- Class B
- 27 kWh
- 19 W
- Diagonal Size
- 17"
- Viewable Size
- 17"
- Panel Type
- TN
- Aspect Ratio
- 5:4
- Native Resolution
- 1280 x 1024
- Pixel Pitch
- 0.264 mm
- Brightness
- 250 cd/m²
- Brightness w/touchscreen
- 225 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Response Time
- 5 ms
- Vertical Refresh Rate
- 56 - 75 Hz
- Horizontal Refresh Rate
- 31.4 - 80 kHz
- Horizontal Viewing Angle
- +85 / -85
- Vertical Viewing Angle
- +80 / -80
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- OSD Languages
- English, German, French, Italian, Spanish, Japanese, Chinese
- Cable management cover, HDCP, edge-to-edge glass, OSD lock, scratch-resistant, glove touch mode
- Black
- 38.7 cm x 20.2 cm x 34.2 cm - with stand
- 5.6 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 1 Watt
Input
- Touch-screen - touchscreen
- Movement Detection Technology
- Projected capacitive
- VGA , HDMI , DisplayPort , USB , Audio line-in
Mechanical
- Tilt
- Tilt Angle
- -5/+90
- Flat Panel Mount Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), 90% light transmittance
- Cables Included
- USB cable , HDMI cable , Audio cable , DisplayPort cable
- Security Slot Type
- Kensington security slot
- Voltage Required
- AC 120/230 V (50/60 Hz)
- 25 Watt
- Power Consumption Stand by
- 2 Watt
- Included Software
- Drivers & Utilities
Bundle includes:
Microsoft Office 365 Business Premium ‘in a box’ 1 year subscription/license worth £96.99 | in stock |
£473.33
