iiyama ProLite T1732MSC-B1AG 17" 1280 x 1024 5ms VGA DVI Monitor
Quicklinx: CW42WS00 Mfr#: T1732MSC-B1AG
Diagonal Size: 17in
Max Resolution: 1280 x 1024
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: DVI, VGA (HD-15)
£398.63 ex VAT
£478.35 inc VAT
The ProLite T1732MSC 17" multi-touch screen is based on projected capacitive technology which thanks to a glass overlay covering the screen guarantees high durability, scratch-resistance and perfect picture performance. The Anti Glare coating helps to avoid issues with reflections and external light sources affecting color reproduction, contrast and sharpness. The touch function remains unaffected even if the glass is scratched. A solid and steady base supports the TouchScreen with an adjustable stand offering full 90 degree positioning angles. Menu Buttons are located on the side of the screen which can be locked to prevent tampering and includes a handy function to deactivate the TouchScreen for cleaning. In addition the edge-to-edge glass design creates an eye-catching finish with high light transmission guaranteeing perfect picture clarity and brilliant colors.
  • Touch technology - Capacitive
    This technology uses a sensor-grid of micro-fine wires integrated into the glass that covers the screen. Touch is detected because electrical characteristics of the sensor grid change when human finger is placed on the glass. Thanks to the glass overlay this technology is highly durable, and the touch function remains unaffected even if the glass is scratched. It offers perfect picture performance and will work with human finger (gloved or not) and magnetic ball.
  • AG coating
    The Anti Glare coating is used in professional-grade displays to help avoid issues with reflections and external light sources affecting color reproduction, contrast and sharpness. It also makes the screen less susceptible to dust, grease and dirt marks.
  • IP54
    The IP Code classifies how resistant a device is to foreign objects and moisture. IP54 means that the monitor will operate in dusty conditions, and will resist splashing water.
  • Scratch resistance
    Scratch resistance is essential for touch solutions used in public places and schools. This is achieved thanks to a glass overlay covering the screen. It guarantees high durability of the touch function and even more importantly the touch function remains unaffected even if the glass is scratched.
  • Speakers
    This LED monitor is equipped with two high quality stereo speakers.
iiyama ProLite T1732MSC-B1AG - LCD monitor - 17"
LCD monitor - 17" - touchscreen
Touch-screen
Panel Type
TN
Aspect Ratio
5:4
Native Resolution
1280 x 1024
Pixel Pitch
0.264 mm
Brightness
225 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms (black-to-white)
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Display Position Adjustments
Tilt
Screen Coating
7H Hard Coating
38.7 cm x 20.2 cm x 34.2 cm
5.6 kg
VCCI, VESA DPMS, CB, cULus, IP54, TUV Bauart
Display Type
LCD monitor / TFT active matrix
Diagonal Size
17"
Panel Type
TN
Aspect Ratio
5:4
Native Resolution
1280 x 1024
Pixel Pitch
0.264 mm
Brightness
225 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
31.4 - 60 kHz
Horizontal Viewing Angle
+80 / -80
Vertical Viewing Angle
+80 / -80
Screen Coating
7H Hard Coating
Controls & Adjustments
Mute, volume, brightness, contrast, H/V position, input select, colour temperature, phase, H-size
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Spanish, Japanese
A-Si technology
38.7 cm x 20.2 cm x 34.2 cm - with stand
5.6 kg
Audio
Speakers - stereo
Output Power / Channel
1 Watt
Input
Touch-screen - touchscreen
Movement Detection Technology
Projected capacitive
VGA , DVI-D , USB , Audio line-in
Mechanical
Tilt
Tilt Angle
-5/+90
VESA Mounting Interface
100 x 100 mm
1 x VGA cable , 1 x DVI cable - DVI-D to DVI-D , 1 x audio cable , 1 x USB cable
Security Slot Type
Kensington security slot
20 Watt
Power Consumption Stand by
2 Watt
Included Software
Drivers & Utilities
Dimensions & Weight Details
Without stand - width: 38.7 cm - depth: 5.45 cm - height: 32 cm , With stand - width: 38.7 cm - depth: 20.2 cm - height: 34.2 cm - weight: 5.6 kg
iiyama ProLite T1732MSC-B1AG 17 Bundle deal on iiyama ProLite T1732MSC-B1AG 17" 1280 x 1024 5ms VGA DVI Monitor
£497.80
Diagonal Size: 17in
Response Time: 5ms
Interfaces: DVI
Interfaces: VGA (HD-15)
Brand: iiyama
Price Range Ex VAT: 300 - 500
