iiyama ProLite T1731SR-W5 17" 1280x1024 5ms VGA HDMI DisplayPort Touchscreen LED Monitor
Quicklinx: FJ19WS00 Mfr#: T1731SR-W5
£259.67 ex VAT
£311.60 inc VAT
ProLite T1731SR-W5 is based on 5 wire resistive touch technology. The price / performance ratio is ideal for the budget conscious user while quality and performance are certainly not compromised. The display inputs include both analogue and digital (VGA, HDMI and DisplayPort) with touchscreen connectivity via USB offering great flexibility. A solid and steady base supports the touchscreen with an adjustable stand offering full 90-degree angles. The ProLite T1731SR-W5 can be used in a variety of environments, especially recommended for shops, restaurants and industrial purposes.
iiyama ProLite T1731SR-W5 - LED monitor - 17"
LED-backlit LCD monitor - 17" - touchscreen
Energy Class
Class E
Energy Consumption per Year
20 kWh
Power Consumption (On mode)
12.9 W
Touch-screen
Panel Type
TN
Aspect Ratio
5:4
Native Resolution
1280 x 1024 at 75 Hz
Pixel Pitch
0.264 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
Voltage
White
38.7 cm x 20.1 cm x 34.2 cm
5.8 kg
Plug and Play, VCCI, GOST, DDC-2B, CB, IP54, TUV Bauart
3-year warranty
Display Type
Energy Class
Class E
20 kWh
Diagonal Size
17"
Panel Type
TN
Aspect Ratio
5:4
Native Resolution
Pixel Pitch
0.264 mm
Brightness
250 cd/m²
Brightness w/touchscreen
200 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
5 ms
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
31 - 80 KHz
Horizontal Viewing Angle
+85 / -85
Vertical Viewing Angle
+80 / -80
Screen Coating
Anti-glare
Backlight Technology
LED backlight
OSD Languages
English, German, French, Italian, Spanish, Japanese, Chinese
Cable management cover, HDCP, scratch-resistant
White
5.8 kg
Audio
Speakers - stereo
Output Power / Channel
1 Watt
Input
Touch-screen - touchscreen
Movement Detection Technology
Resistive
VGA , HDMI , DisplayPort , USB , Audio line-in
Mechanical
Tilt
Tilt Angle
-5/+90
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), 80% light transmittance
USB cable , HDMI cable , Audio cable , DisplayPort cable
Security Slot Type
Kensington security slot
Input Voltage
12.9 W
12.9 kWh/1000h
Power Consumption (Typical)
20 Watt
Power Consumption Stand by
2 Watt
Included Software
Drivers & Utilities
Limited warranty - 3 years
