iiyama ProLite T1731SR-B1 17" 1280x1024 5ms VGA DVI Touchscreen LCD Monitor
Quicklinx: B5C3WS00 Mfr#: T1731SR-B1
ProLite T1731SR is based on the 5 Wire Resistive technology. Price/performance ratio is ideal for the budget conscious user while quality and specification is certainly not compromised. The display inputs include both analog and digital (DVI) with Touchscreen connectivity via either USB or RS-232 which offers greater than typical flexibility. A solid and steady base supports the TouchScreen with an adjustable stand offering full 90 degree angles. Extensive touch utilities allow for 4 point calibration and either 9/25 point linearization.
  • DVI-I/DVI-D input connector
    This device is equipped with one DVI-I or DVI-D input connector.
  • VESA mounting
    This device can be installed with the use of holders, which comply with the VESA standard. Thanks to this functionality, with the help of proper handles, the device can be mounted on a wall, a ceiling or other surface.
Iiyama ProLite T1731SR-B1 - LCD monitor - 17"
LCD monitor - 17"
Built-in Devices
Touch-screen , stereo speakers
Panel Type
TN
Native Resolution
1280 x 1024
Pixel Pitch
0.264 mm
Brightness
200 cd/m2
Contrast Ratio
900:1
Response Time
5 ms
Colour Support
16.2 million colours
Input Connectors
DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
Tilt
38.7 cm x 34.2 cm x 20.2 cm
5.7 kg
Plug and Play, FCC Class B certified, UL, TUV, VCCI Class B ITE, cUL
Display Type
LCD monitor / TFT active matrix
Diagonal Size
17"
Built-in Devices
Stereo speakers
Panel Type
TN
Native Resolution
1280 x 1024
Pixel Pitch
0.264 mm
Brightness
200 cd/m2
Contrast Ratio
900:1
Colour Support
Response Time
5 ms
Vertical Refresh Rate
75 Hz
Horizontal Refresh Rate
80 kHz
Horizontal Viewing Angle
+85 / -80
Vertical Viewing Angle
+85 / -80
Controls & Adjustments
Volume, brightness, contrast, H/V position, input select, colour temperature, phase, clock
OSD Languages
English, German, French, Italian, Spanish, Japanese, Chinese
5.7 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
1 Watt
Input
Touch-screen
Movement Detection Technology
Resistive
Serial , DVI-D , VGA , Audio line-in , USB
Mechanical
Tilt
Flat Panel Mount Interface
100 x 100 mm
Wall mountable
1 x VGA cable , 1 x DVI cable , 1 x audio cable , 1 x serial cable , 1 x power cable , 1 x USB cable
Power Supply
Internal
AC 120/230 V ( 50/60 Hz )
20 Watt
Power Consumption Stand by / Sleep
2 Watt
Included Software
Drivers & Utilities
Apple MacOS, Microsoft Windows 95/98/ME/2000/XP
B5C3 C2G 2m USB 2.0 A/B Cable - Black In Stock £3.82
B5C3 C2G 5m USB 2.0 A/B Cable - Black In Stock £4.99
B5C3 C2G 5m USB 2.0 A Male to A Female Active Extension Cable In Stock £12.46
B5C3 C2G 12m USB 2.0 A/A Active Extension Cable In Stock £16.36
B5C3 C2G USB Superbooster Extender Kit In Stock £36.93
B5C3 C2G Trulink® USB to Gigabit Ethernet Adapter In Stock £22.84
B5C3 C2G USB to HDMI Adapter with Audio Up To 1080p In Stock £42.30
