iiyama ProLite T1721MSC-B1 17" 1280 x 1024 5ms VGA DVI Touch Monito
Quicklinx: CW40WS00 Mfr#: T1721MSC-B1
Diagonal Size: 17in
Max Resolution: 1280 x 1024
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: VGA (HD-15), DVI
£278.38 ex VAT
£334.05 inc VAT
The ProLite T1721MSC-B1 17 inch touchscreen is based on projected capacitive technology, offering optimal seamless and accurate touch response. Due to its glass overlay, it guarantees high durability,
  • Capacitive touch technology
    This technology uses a sensor grid of micro-fine wires integrated into the glass that covers the screen. Touch is detected because electrical characteristics of the sensor grid change when human finger is placed on the glass. Thanks to the glass overlay this technology is highly durable, and the touch function remains unaffected even if the glass is scratched. It offers perfect picture performance and will work with human finger (also latex gloved) and stylus pen.
  • Scratch resistance
    Scratch resistance is essential for touch solutions used in public places and schools. This is achieved thanks to a glass overlay covering the screen. It guarantees high durability of the touch function and even more importantly the touch function remains unaffected even if the glass is scratched.
  • High-quality stereo speakers
    This LED monitor is equipped with two high-quality stereo speakers.
iiyama ProLite T1721MSC-B1 - LED monitor - 17"
LED-backlit LCD monitor - 17" - touchscreen
Energy Class
Class F
Power Consumption (On mode)
14.4 W
Touch-screen
Panel Type
TN
Aspect Ratio
5:4
Native Resolution
1280 x 1024 at 75 Hz
Pixel Pitch
0.264 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Display Position Adjustments
Tilt
Screen Coating
7H Hard Coating
Voltage
39.25 cm x 19.8 cm x 36.4 cm
4.4 kg
VESA DPMS, CB, cULus, TUV Bauart, CU
3-year warranty
Display Type
Energy Class
Class F
Diagonal Size
17"
Panel Type
TN
Aspect Ratio
5:4
Native Resolution
Pixel Pitch
0.264 mm
Brightness
250 cd/m²
Brightness w/touchscreen
215 cd/m²
Contrast Ratio
1000:1
Colour Support
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
31.4 - 80 kHz
Horizontal Viewing Angle
+85 / -85
Vertical Viewing Angle
+80 / -80
Screen Coating
7H Hard Coating
Backlight Technology
LED backlight
OSD Languages
English, German, French, Italian, Polish, Russian, Spanish, Dutch
HID Compliant, scratch-resistant, Projected Capacitive Touch (P-CAP) technology
4.4 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
Input
Touch-screen - touchscreen
Movement Detection Technology
Projected capacitive
DVI-D , VGA , USB
Mechanical
Tilt
Tilt Angle
-10/+70
VESA Mounting Interface
100 x 100 mm
1 x VGA cable , 1 x USB cable , 1 x DVI cable
Input Voltage
14.4 W
14.4 kWh/1000h
Power Consumption (Typical)
20 Watt
Linux, Microsoft Windows Vista / XP / 7 / 8, Windows 10
Limited warranty - 3 years
Diagonal Size: 17in
Response Time: 5ms
Interfaces: DVI
Brand: iiyama
