The 15.6" LED-backlit ProLite monitor uses Projective Capacitive Multi-Touch technology, built into an eye catching bezel with edge-to-edge glass. The screen features DVI and VGA inputs and a rugged bezel front making it suitable for demanding environments. The ProLite monitor is the ideal solution for in-store retail and kiosk integration.
Touch technology
This technology uses a sensor-grid of micro-fine wires integrated into the glass that covers the screen. Touch is detected because electrical characteristics of the sensor grid change when human finger is placed on the glass. Thanks to the glass overlay this technology is highly durable, and the touch function remains unaffected even if the glass is scratched. It offers perfect picture performance and will work with human finger (gloved or not) and magnetic ball. -
Scratch resistance
Scratch resistance is essential for touch solutions used in public places and schools. This is achieved thanks to a glass overlay covering the screen. It guarantees high durability of the touch function and even more importantly the touch function remains unaffected even if the glass is scratched. -
LED backlit
A typical CCFL LCD uses four backlight lamps. Using LED diodes considerably lowers the power consumption and reduces the CO2 emission into the environment making this LCD a true eco-friendly product.
- iiyama ProLite T1634MC-B4X - LED monitor - 15.6"
- LED-backlit LCD monitor - 15.6" - touchscreen
- Touch-screen
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- 1366 x 768
- Pixel Pitch
- 0.252 mm
- Brightness
- 400 cd/m²
- Contrast Ratio
- 500:1
- Response Time
- 8 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI-D, VGA
- Tilt
- Screen Coating
- 7H Hard Coating
- Black
- 38.1 cm x 20.2 cm x 28.55 cm
- 4.4 kg
- VCCI, DDC-2B, VESA DPMS, IP54, TUV Bauart
- Display Type
- Diagonal Size
- 15.6"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- 1366 x 768
- Pixel Pitch
- 0.252 mm
- Brightness
- 400 cd/m²
- Brightness w/touchscreen
- 360 cd/m²
- Contrast Ratio
- 500:1
- Colour Support
- Response Time
- 8 ms
- Vertical Refresh Rate
- 56 - 75 Hz
- Horizontal Refresh Rate
- 31.4 - 60.3 kHz
- Horizontal Viewing Angle
- +85 / -85
- Vertical Viewing Angle
- +80 / -80
- Screen Coating
- 7H Hard Coating
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Brightness, contrast, H/V position, input select, colour temperature, phase, H-size
- OSD Languages
- Chinese (traditional), Chinese (simplified), English, German, French, Italian, Spanish, Japanese
- Edge-to-edge glass, HID Compliant, scratch-resistant, Projected Capacitive Touch (P-CAP) technology
- Black
- 38.1 cm x 20.2 cm x 28.55 cm - with stand
- 4.4 kg
Input
- Touch-screen - touchscreen
- Movement Detection Technology
- Projected capacitive
- VGA , DVI-D , USB (Type B)
Mechanical
- Tilt
- Tilt Angle
- -5/+90
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable , 1 x DVI cable , 1 x USB cable
- Voltage Required
- DC 12 V
- 16 Watt
- Included Software
- Drivers & Utilities
- OS Required
- Microsoft Windows NT 4.0, Microsoft Windows 95/98, Microsoft Windows CE, Linux, Microsoft Windows 2000, Apple MacOS X, Microsoft Windows XP, Microsoft Windows Vista, Microsoft Windows 7 / 8 / 10
- Dimensions & Weight Details
- Without stand - width: 38.1 cm - depth: 5.3 cm - height: 23.05 cm , With stand - width: 38.1 cm - depth: 20.2 cm - height: 28.55 cm - weight: 4.4 kg
Bundle includes:
Microsoft Office 365 Business Premium ‘in a box’ 1 year subscription/license worth £99.17 | in stock |
£491.37
