iiyama ProLite T1633MC-B1 15.6" 1366x768 8ms VGA HDMI DisplayPort Touchscreen LED Monitor
Quicklinx: FJ1HWS00 Mfr#: T1633MC-B1
Diagonal Size: 15.6in
Max Resolution: 1366 x 768
Response Time: 8ms
Interfaces: HDMI, DisplayPort, VGA (HD-15)
£305.98 ex VAT
£367.17 inc VAT
The LED-backlit ProLite T1633MC-B1 is built into an eye-catching bezel with edge-to-edge glass. The screen features triple inputs and comes with a rugged bezel, making it suitable for demanding environments.
iiyama ProLite T1633MC-B1 - LED monitor - 15.6"
LED-backlit LCD monitor - 15.6" - touchscreen
Energy Class
Class F
Power Consumption (On mode)
12.8 W
Touch-screen, USB 2.0 hub
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
1366 x 768 at 60 Hz
Pixel Pitch
0.252 mm
Brightness
300 cd/m²
Contrast Ratio
500:1
Response Time
8 ms
Colour Support
16.7 million colours (8-bit)
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Tilt
Screen Coating
Matte
Voltage
DC 12 V
Black, matte
38.9 cm x 25.4 cm x 31.25 cm
4.5 kg
Plug and Play, DDC-2B, CB, RoHS, WEEE, REACH, IP54, TUV Bauart, ERP
3-year warranty
Display Type
Energy Class
Class F
Diagonal Size
15.6"
Built-in Devices
USB 2.0 hub
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
1366 x 768 at 60 Hz
Pixel Pitch
0.252 mm
Brightness
300 cd/m²
Brightness w/touchscreen
255 cd/m²
Contrast Ratio
500:1
Colour Support
Response Time
8 ms
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
31.4 - 60.3 kHz
Horizontal Viewing Angle
+80 / -80
Vertical Viewing Angle
+80 / -80
Screen Coating
Matte
Backlight Technology
LED backlight
OSD Languages
Czech, English, German, French, Italian, Portuguese, Polish, Russian, Spanish, Dutch, Japanese, Chinese
Cable management cover, HDCP, ECO button, edge-to-edge glass, OSD lock, scratch-resistant, blue light reduction, glove touch mode, i-Style Color
Black, matte
4.5 kg
Input
Touch-screen - touchscreen
Movement Detection Technology
Projected capacitive
VGA (HD-15) , HDMI (HDCP) , DisplayPort , 2 x USB
Mechanical
Tilt
Tilt Angle
-5/+90
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), 85% light transmittance
Cable cover
1 x USB cable - 1.8 m , 1 x HDMI cable - 1.8 m , 1 x DisplayPort cable - 1.8 m
Security Slot Type
Kensington security slot
Input Voltage
DC 12 V
12.8 W
12.8 kWh/1000h
Power Consumption (Typical)
13.5 Watt
Power Consumption Stand by
2 Watt
Power Consumption (Off Mode)
2 Watt
Limited warranty - 3 years
Response Time: 8ms
Interfaces: HDMI
Interfaces: DisplayPort
Interfaces: VGA (HD-15)
Brand: iiyama
