iiyama ProLite T1532SR-B5 15" 1024x768 8ms VGA HDMI DisplayPort Touchscreen LED Monitor
Quicklinx: DXPSWS00 Mfr#: T1532SR-B5
The ProLite T1532SR-B5 is based on 5 wire resistive touch technology. The price / performance ratio is ideal for the budget conscious user while quality and performance are certainly not compromised. The display inputs include both analog and digital (HDMI and DisplayPort) with touchscreen connectivity via USB offering great flexibility. A solid and steady base supports the touchscreen with an adjustable stand offering full 90-degree angles. The ProLite T1532SR-B5 can be used in a variety of environments, especially recommended for shops, restaurants and industrial purposes.
iiyama ProLite T1532SR-B5 - LED monitor - 15"
LED-backlit LCD monitor - 15" - touchscreen
Energy Class
Class A
Touch-screen
Panel Type
TN
Aspect Ratio
4:3
Native Resolution
1024 x 768
Pixel Pitch
0.297 mm
Brightness
370 cd/m²
Contrast Ratio
700:1
Response Time
8 ms
Colour Support
16.2 million colours
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, matte
Voltage
35.1 cm x 20.1 cm x 30.6 cm
4.8 kg
VCCI, DDC-2B, CB, cULus, IP54, TUV Bauart, CU
Display Type
Energy Class
Class A
Diagonal Size
15"
Panel Type
TN
Aspect Ratio
4:3
Native Resolution
1024 x 768
Pixel Pitch
0.297 mm
Brightness
370 cd/m²
Brightness w/touchscreen
300 cd/m²
Contrast Ratio
700:1
Colour Support
Response Time
8 ms
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
31.5 - 60 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
Anti-glare, matte
Backlight Technology
LED backlight
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Spanish, Japanese
HDCP
4.8 kg
Audio
Speakers - stereo
Output Power / Channel
1 Watt
Input
Touch-screen - touchscreen
Movement Detection Technology
Resistive
HDMI , DisplayPort , VGA , Audio line-in , USB
Mechanical
Tilt
Tilt Angle
-5/+90
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), 80% light transmittance
Cable cover
1 x USB cable , 1 x HDMI cable , 1 x audio cable , 1 x DisplayPort cable
Security Slot Type
Kensington security slot
Input Voltage
Power Consumption (Typical)
16 Watt
Power Consumption Stand by
2 Watt
Included Software
Drivers & Utilities
