iiyama ProLite T1532SR-B3 15" 1024 x 768 8ms VGA DVI Touch Monitor
Quicklinx: CW3XWS00 Mfr#: T1532SR-B3
ProLite T1532SR is an incredibly powerful touch solution based on the latest 5 Wire Resistive technology. Price/performance ratio is ideal for the budget conscious user while quality and specification is certainly not compromised. The display inputs include both Analog and Digital (DVI) with Touchscreen connectivity via either USB or RS-232 which offers greater than typical flexibility.
A solid and steady base supports the TouchScreen with an adjustable stand offering full 90 degree positioning angles. Extensive Touch Utilities allow for 4 point calibration and 9/25 point linearization. Menu Buttons are located on the side of the screen which can be locked to prevent tampering, and includes a handy function to deactivate the Touch Screen for cleaning. In addition the bezel free design creates an eye-catching finish with high light transmission guaranteeing perfect picture clarity and brilliant colors.
iiyama ProLite T1532SR-B3 - LED monitor - 15"
LED-backlit LCD monitor - 15" - touchscreen
Touch-screen
Panel Type
TN
Aspect Ratio
4:3
Native Resolution
1024 x 768
Pixel Pitch
0.297 mm
Brightness
350 cd/m²
Contrast Ratio
700:1
Response Time
8 ms (black-to-white)
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
Voltage
35.1 cm x 20.1 cm x 30.6 cm
4.8 kg
VCCI, VESA DPMS, CB, cULus, IP54, TUV Bauart
Display Type
Diagonal Size
15"
Panel Type
TN
Aspect Ratio
4:3
Native Resolution
1024 x 768
Pixel Pitch
0.297 mm
Brightness
350 cd/m²
Contrast Ratio
700:1
Colour Support
Response Time
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
31.5 - 60.2 kHz
Horizontal Viewing Angle
+70 / -70
Vertical Viewing Angle
+60 / -65
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Controls & Adjustments
Mute, volume, brightness, contrast, H/V position, input select, colour temperature, phase, H-size
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Spanish, Japanese
A-Si technology
35.1 cm x 20.1 cm x 30.6 cm - with stand
4.8 kg
Audio
Speakers - stereo
Output Power / Channel
1 Watt
Input
Touch-screen - touchscreen
Movement Detection Technology
Resistive
Serial , DVI-D , VGA (HD-15) , Audio line-in , USB (Type B)
Mechanical
Tilt
Tilt Angle
-5/+90
VESA Mounting Interface
100 x 100 mm
1 x VGA cable , 1 x DVI cable - DVI-D to DVI-D , 1 x audio cable , 1 x serial cable , 1 x USB cable
Security Slot Type
Kensington security slot
Input Voltage
Power Consumption (Typical)
20 Watt
Power Consumption Stand by
2 Watt
Included Software
Drivers & Utilities
Dimensions & Weight Details
Without stand - width: 35.1 cm - depth: 5.9 cm - height: 27.5 cm , With stand - width: 35.1 cm - depth: 20.1 cm - height: 30.6 cm - weight: 4.8 kg
5 °C
35 °C
20 - 80% (non-condensing)
