iiyama ProLite T1532MSC-B5X 15" 1024x768 8ms VGA HDMI DisplayPort Touchscreen LED Monitor
Quicklinx: FJ1JWS00 Mfr#: T1532MSC-B5X
Diagonal Size: 15in
Max Resolution: 1024 x 768
Response Time: 8ms
Speakers: Speaker(s)
Interfaces: DisplayPort, HDMI, VGA (HD-15)
£303.59 ex VAT
£364.30 inc VAT
The ProLite T1532MSC-B5X multi-touch screen is based on projected capacitive technology which thanks to a glass overlay covering the screen guarantees high durability, scratch-resistance and perfect picture performance. The touch function remains unaffected even if the glass is scratched. A solid and steady base supports the touchscreen with an adjustable stand offering full 90 degree positioning angles.
iiyama ProLite T1532MSC-B5X - LED monitor - 15"
LED-backlit LCD monitor - 15" - touchscreen
Touch-screen
Panel Type
TN
Aspect Ratio
4:3
Native Resolution
XGA 1024 x 768 at 75 Hz
Pixel Pitch
0.297 mm
Brightness
370 cd/m²
Contrast Ratio
700:1
Response Time
8 ms (black-to-white)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Tilt
Screen Coating
Matte
35.1 cm x 20.2 cm x 30.65 cm
4.5 kg
Plug and Play, VCCI, CB, IP54, TUV Bauart, EAC
3-year warranty
Display Type
Diagonal Size
15"
Viewable Size
15"
Panel Type
TN
Aspect Ratio
4:3
Native Resolution
Pixel Pitch
0.297 mm
Brightness
370 cd/m²
Brightness w/touchscreen
330 cd/m²
Contrast Ratio
700:1
Colour Support
Response Time
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
31.47 - 60.02 kHz
Horizontal Viewing Angle
+85 / -85
Vertical Viewing Angle
+80 / -80
Screen Coating
Matte
Backlight Technology
LED backlight
OSD Languages
English, German, French, Italian, Spanish, Japanese, Chinese
HDCP, edge-to-edge glass, OSD lock, scratch-resistant
35.1 cm x 20.2 cm x 30.65 cm - with stand
4.5 kg
Audio
Speakers - stereo
Output Power / Channel
1 Watt
Input
Touch-screen - touchscreen
Movement Detection Technology
Projected capacitive
VGA , HDMI , DisplayPort , USB , Audio line-in (mini-jack)
Mechanical
Tilt
Tilt Angle
-5/+90
VESA Mounting Interface
100 x 100 mm
Cable cover
1 x USB cable - 1.8 m , 1 x HDMI cable - 1.8 m , 1 x audio cable - 1.8 m , 1 x DisplayPort cable - 1.8 m
Security Slot Type
Kensington security slot
16 Watt
Power Consumption Stand by
2 Watt
Included Software
Drivers & Utilities
Dimensions & Weight Details
With stand - width: 35.1 cm - depth: 20.2 cm - height: 30.65 cm - weight: 4.5 kg , Without stand - width: 35.1 cm - depth: 5.45 cm - height: 27.6 cm
Limited warranty - 3 years
20 - 80% (non-condensing)
Diagonal Size: 15in
Response Time: 8ms
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: iiyama
Price Range Ex VAT: 300 - 500
