iiyama ProLite T1532MSC-B5AG 15" 1024x768 8ms VGA HDMI DisplayPort Touchscreen LED Monitor
Quicklinx: FJ1KWS00 Mfr#: T1532MSC-B5AG
Diagonal Size: 15in
Max Resolution: 1024 x 768
Response Time: 8ms
Speakers: Speaker(s)
Interfaces: DisplayPort, VGA (HD-15), HDMI
£369.50 ex VAT
£443.40 inc VAT
The ProLite T1532MSC multi-touch screen is based on projected capacitive technology which thanks to a glass overlay covering the screen guarantees high durability, scratch-resistance and perfect picture performance. The anti-glare coating helps to avoid issues with reflections and external light sources affecting color reproduction, contrast and sharpness. The touch function remains unaffected even if the glass is scratched.
iiyama ProLite T1532MSC-B5AG - LED monitor - 15"
LED-backlit LCD monitor - 15" - touchscreen
Energy Class
Class E
Energy Consumption per Year
23 kWh
Power Consumption (On mode)
10.2 W
Touch-screen
Panel Type
TN
Aspect Ratio
4:3
Native Resolution
1024 x 768 at 75 Hz
Pixel Pitch
0.297 mm
Brightness
370 cd/m²
Contrast Ratio
700:1
Response Time
8 ms
Colour Support
16.2 million colours
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, matte
Voltage
35.1 cm x 20.2 cm x 30.65 cm
4.5 kg
Plug and Play, VCCI, DDC-2B, CB, cULus, IP54, TUV Bauart, CU
3-year warranty
Display Type
Energy Class
Class E
23 kWh
Diagonal Size
15"
Panel Type
TN
Aspect Ratio
4:3
Native Resolution
1024 x 768 at 75 Hz
Pixel Pitch
0.297 mm
Brightness
370 cd/m²
Brightness w/touchscreen
315 cd/m²
Contrast Ratio
700:1
Colour Support
Response Time
8 ms
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
31.4 - 60 kHz
Horizontal Viewing Angle
+85 / -85
Vertical Viewing Angle
+80 / -80
Screen Coating
Anti-glare, matte
Backlight Technology
LED backlight
OSD Languages
English, German, French, Italian, Spanish, Japanese, Chinese
HDCP, edge-to-edge glass, OSD lock, scratch-resistant
4.5 kg
Audio
Speakers - stereo
Output Power / Channel
1 Watt
Input
Touch-screen - touchscreen
Movement Detection Technology
Projected capacitive
VGA , HDMI , DisplayPort , USB , Audio line-in (mini-jack)
Mechanical
Tilt
Tilt Angle
-5/+90
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), 85% light transmittance
Cable cover
1 x USB cable , 1 x HDMI cable , 1 x audio cable , 1 x DisplayPort cable
Security Slot Type
Kensington security slot
Input Voltage
10.2 W
10.2 kWh/1000h
Power Consumption (Typical)
16 Watt
Power Consumption Stand by
2 Watt
Included Software
Drivers & Utilities
Limited warranty - 3 years
Diagonal Size: 15in
Response Time: 8ms
Interfaces: VGA (HD-15)
Interfaces: HDMI
Brand: iiyama
