Product
iiyama ProLite T1532MSC 15" 1024x768 VGA DVI-D Touch Screen Monitor
Quicklinx: BVPFWS00 Mfr#: T1532MSC-B3X
The ProLite T1532MSC 15" multi-touch screen is based on projected capacitive technology which thanks to a glass overlay covering the screen guarantees high durability, scratch-resistance and perfect picture performance. The touch function remains unaffected even if the glass is scratched. A solid and steady base supports the TouchScreen with an adjustable stand offering full 90 degree positioning angles. Menu Buttons are located on the side of the screen which can be locked to prevent tampering and includes a handy function to deactivate the TouchScreen for cleaning. In addition the edge-to-edge glass design creates an eye-catching finish with high light transmission guaranteeing perfect picture clarity and brilliant colors.
  • IP54
    The IP Code classifies how resistant a device is to foreign objects and moisture. IP54 means that the monitor will operate in dusty conditions, and will resist splashing water.
  • Scratch resistance
    Scratch resistance is essential for touch solutions used in public places and schools. This is achieved thanks to a glass overlay covering the screen. It guarantees high durability of the touch function and even more importantly the touch function remains unaffected even if the glass is scratched
  • VESA
    VESA mount compliance means you can easily mount the LFD to any mounting that complies with the VESA standard.
iiyama ProLite T1532MSC-B3X - LED monitor - 15"
LED-backlit LCD monitor - 15" - touchscreen
Touch-screen
Panel Type
TN
Aspect Ratio
4:3
Native Resolution
1024 x 768
Pixel Pitch
0.297 mm
Brightness
350 cd/m²
Contrast Ratio
700:1
Response Time
8 ms (black-to-white)
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Display Position Adjustments
Tilt
Screen Coating
7H Hard Coating
35.1 cm x 20.2 cm x 30.65 cm
4.5 kg
VCCI, CB, cULus, IP54, TUV Bauart
Display Type
Diagonal Size
15"
Viewable Size
15"
Panel Type
TN
Aspect Ratio
4:3
Native Resolution
1024 x 768
Pixel Pitch
0.297 mm
Brightness
350 cd/m²
Brightness w/touchscreen
315 cd/m²
Contrast Ratio
700:1
Colour Support
Response Time
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
31.4 - 60 kHz
Horizontal Viewing Angle
+70 / -70
Vertical Viewing Angle
+65 / -60
Screen Coating
7H Hard Coating
Backlight Technology
LED backlight
Controls & Adjustments
Mute, volume, brightness, contrast, H/V position, input select, colour temperature, phase, H-size
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Spanish, Japanese
HID Compliant, scratch-resistant
35.1 cm x 20.2 cm x 30.65 cm - with stand
4.5 kg
Audio
Speakers - stereo
Output Power / Channel
1 Watt
Input
Touch-screen - touchscreen
Movement Detection Technology
Projected capacitive
VGA (HD-15) , DVI-D , USB (Type B) , Audio line-in (mini-jack)
Mechanical
Tilt
Tilt Angle
-5/+90
Flat Panel Mount Interface
100 x 100 mm
1 x VGA cable , 1 x DVI cable - DVI-D to DVI-D , 1 x audio cable , 1 x USB cable
Security Slot Type
Kensington security slot
20 Watt
Power Consumption Stand by
2 Watt
Included Software
Driver
Dimensions & Weight Details
Without stand - width: 35.1 cm - depth: 5.45 cm - height: 27.6 cm , With stand - width: 35.1 cm - depth: 20.2 cm - height: 30.65 cm - weight: 4.5 kg
20 - 80% (non-condensing)
BVPF C2G 2m USB 2.0 A/B Cable - Black In Stock £3.84
BVPF C2G 5m USB 2.0 A/B Cable - Black In Stock £4.98
BVPF C2G 4-Port USB 2.0 Aluminum Hub In Stock £14.78
BVPF C2G 12m USB 2.0 A/A Active Extension Cable In Stock £16.29
BVPF C2G USB Superbooster Extender Kit In Stock £36.81
BVPF C2G Trulink® USB to Gigabit Ethernet Adapter In Stock £22.76
BVPF C2G USB to HDMI Adapter with Audio Up To 1080p In Stock £42.30
