iiyama ProLite T1531SR-W3 15" 1024 x 768 8ms VGA DVI Touch Monitor
Quicklinx: CW3WWS00 Mfr#: T1531SR-W3
ProLite T1531SR is based on the advanced 5-Wire Resistive technology. Price / performance ratio is ideal for the budget conscious user while quality and specification is certainly not compromised. The display inputs include both analog and digital (DVI) with touchscreen connectivity via either USB or RS-232 which offers greater than typical flexibility. A solid and steady base supports the TouchScreen with an adjustable stand offering full 90 degree angles. Extensive touch utilities allow for 4 point calibration and either 9/25 point linearization.
  • 5-Wire Resistive Touchscreen technology
    5-wire resistive touchscreens are very durable and can be used in a variety of environments. They are especially recommended for shops, restaurants and industrial purposes.
  • Speakers
    This LED monitor is equipped with two high-quality stereo speakers.
iiyama ProLite T1531SR-W3 - LED monitor - 15"
LED-backlit LCD monitor - 15" - touchscreen
Touch-screen
Panel Type
TN
Aspect Ratio
4:3
Native Resolution
1024 x 768
Pixel Pitch
0.297 mm
Brightness
350 cd/m²
Contrast Ratio
700:1
Response Time
8 ms (black-to-white)
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
Voltage
AC 120/230 V (50 - 60 Hz)
White
35.1 cm x 20.1 cm x 30.6 cm
4.8 kg
VCCI, DDC-2B, VESA DPMS, CB, cULus, IP54, TUV Bauart
Display Type
Diagonal Size
15"
Panel Type
TN
Aspect Ratio
4:3
Native Resolution
1024 x 768
Pixel Pitch
0.297 mm
Brightness
350 cd/m²
Brightness w/touchscreen
350 cd/m²
Contrast Ratio
700:1
Colour Support
Response Time
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
31.5 - 60.2 kHz
Horizontal Viewing Angle
140
Vertical Viewing Angle
125
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Colour Temperature
9300K, 6500K, 5500K, 7500K
Controls & Adjustments
Mute, volume, brightness, contrast, H/V position, input select, colour temperature, phase, H-size
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Spanish, Japanese
5-Wire Resistive Touch Screen Technology, a-Si technology
White
35.1 cm x 20.1 cm x 30.6 cm - with stand
4.8 kg
Audio
Speakers - stereo
Output Power / Channel
1 Watt
Input
Touch-screen - touchscreen
Movement Detection Technology
Resistive
DVI-D , VGA (HD-15) , Serial (DB-9) , USB (Type B) , Audio line-in (mini-jack)
Mechanical
Tilt
Tilt Angle
-5/+90
VESA Mounting Interface
100 x 100 mm
1 x VGA cable - VGA to VGA , 1 x DVI cable - DVI-D to DVI-D , 1 x serial cable , 1 x audio cable - 3.5 mm to 3.5 mm , 1 x USB cable - USB Type A to B
Security Slot Type
Kensington security slot
Input Voltage
Power Consumption (Typical)
20 Watt
Power Consumption Stand by
2 Watt
Included Software
Driver
Microsoft Windows CE, Linux, Microsoft Windows 2000 / NT4.0, Apple MacOS X, Microsoft Windows 95/98/ME/2000/XP/Vista/7
Dimensions & Weight Details
Without stand - width: 35.1 cm - depth: 5.9 cm - height: 27.5 cm , With stand - width: 35.1 cm - depth: 20.1 cm - height: 30.6 cm - weight: 4.8 kg
20 - 80% (non-condensing)
