ProLite T1531SR is based on the advanced 5-Wire Resistive technology. Price / performance ratio is ideal for the budget conscious user while quality and specification is certainly not compromised. The display inputs include both analog and digital (DVI) with touchscreen connectivity via either USB or RS-232 which offers greater than typical flexibility. A solid and steady base supports the TouchScreen with an adjustable stand offering full 90 degree angles. Extensive touch utilities allow for 4 point calibration and either 9/25 point linearization.
5-Wire Resistive Touchscreen technology
5-wire resistive touchscreens are very durable and can be used in a variety of environments. They are especially recommended for shops, restaurants and industrial purposes. -
Speakers
This LED monitor is equipped with two high-quality stereo speakers.
- iiyama ProLite T1531SR-W3 - LED monitor - 15"
- LED-backlit LCD monitor - 15" - touchscreen
- Touch-screen
- Panel Type
- TN
- Aspect Ratio
- 4:3
- Native Resolution
- 1024 x 768
- Pixel Pitch
- 0.297 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 700:1
- Response Time
- 8 ms (black-to-white)
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI-D, VGA
- Tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V (50 - 60 Hz)
- White
- 35.1 cm x 20.1 cm x 30.6 cm
- 4.8 kg
- VCCI, DDC-2B, VESA DPMS, CB, cULus, IP54, TUV Bauart
- Display Type
- Diagonal Size
- 15"
- Panel Type
- TN
- Aspect Ratio
- 4:3
- Native Resolution
- 1024 x 768
- Pixel Pitch
- 0.297 mm
- Brightness
- 350 cd/m²
- Brightness w/touchscreen
- 350 cd/m²
- Contrast Ratio
- 700:1
- Colour Support
- Response Time
- Vertical Refresh Rate
- 56 - 75 Hz
- Horizontal Refresh Rate
- 31.5 - 60.2 kHz
- Horizontal Viewing Angle
- 140
- Vertical Viewing Angle
- 125
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- Colour Temperature
- 9300K, 6500K, 5500K, 7500K
- Controls & Adjustments
- Mute, volume, brightness, contrast, H/V position, input select, colour temperature, phase, H-size
- OSD Languages
- Chinese (traditional), Chinese (simplified), English, German, French, Italian, Spanish, Japanese
- 5-Wire Resistive Touch Screen Technology, a-Si technology
- White
- 35.1 cm x 20.1 cm x 30.6 cm - with stand
- 4.8 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 1 Watt
Input
- Touch-screen - touchscreen
- Movement Detection Technology
- Resistive
- DVI-D , VGA (HD-15) , Serial (DB-9) , USB (Type B) , Audio line-in (mini-jack)
Mechanical
- Tilt
- Tilt Angle
- -5/+90
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable - VGA to VGA , 1 x DVI cable - DVI-D to DVI-D , 1 x serial cable , 1 x audio cable - 3.5 mm to 3.5 mm , 1 x USB cable - USB Type A to B
- Security Slot Type
- Kensington security slot
- Input Voltage
- Power Consumption (Typical)
- 20 Watt
- Power Consumption Stand by
- 2 Watt
- Included Software
- Driver
- OS Required
- Microsoft Windows CE, Linux, Microsoft Windows 2000 / NT4.0, Apple MacOS X, Microsoft Windows 95/98/ME/2000/XP/Vista/7
- Dimensions & Weight Details
- Without stand - width: 35.1 cm - depth: 5.9 cm - height: 27.5 cm , With stand - width: 35.1 cm - depth: 20.1 cm - height: 30.6 cm - weight: 4.8 kg
- 0 °C
- 40 °C
- 20 - 80% (non-condensing)
