iiyama ProLite T1531SR-B3 15" 1024x768 8ms VGA DVI-D LED Touchscreen Monitor
Quicklinx: BV9LWS00 Mfr#: T1531SR-B3
ProLite T1531SR is based on the latest 5 wire resistive technology. Price/performance ratio is ideal for the budget conscious user while quality and specification is certainly not compromised. The display inputs include both analog and digital (DVI) with Touchscreen connectivity via either USB or RS-232 which offers greater than typical flexibility. A solid and steady base supports the touchscreen with an adjustable stand offering full 90 degree angles. Extensive touch utilities allow for 4 point calibration and either 9/25 point linerization.
  • LED-backlit
    A typical CCFL LCD uses four backlight lamps. Using LED diodes considerably lowers the power consumption and reduces the CO2 emission into the environment making this LCD a true ECO-Friendly product.
  • Touch technology - resistive
    5-wire resistive touchscreens are very durable and can be used in a variety of environments. They are especially recommended for shops, restaurants and industrial purposes.
  • IP54
    The IP Code classifies how resistant a device is to foreign objects and moisture. IP54 means that the monitor will operate in dusty conditions, and will resist splashing water.
iiyama ProLite T1531SR-B3 - LED monitor - 15"
LED-backlit LCD monitor - 15" - touchscreen
Touch-screen
Panel Type
TN
Aspect Ratio
4:3
Native Resolution
1024 x 768
Pixel Pitch
0.297 mm
Brightness
350 cd/m²
Contrast Ratio
700:1
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Voltage
AC 120/230 V (50 - 60 Hz)
35.1 cm x 20.1 cm x 30.6 cm
4.8 kg
VCCI, DDC-2B, VESA DPMS, CB, cULus, IP54, TUV Bauart
Display Type
Diagonal Size
15"
Viewable Size
14.96"
Panel Type
TN
Aspect Ratio
4:3
Native Resolution
1024 x 768
Pixel Pitch
0.297 mm
Brightness
350 cd/m²
Brightness w/touchscreen
350 cd/m²
Contrast Ratio
700:1
Colour Support
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
31.5 - 60.2 kHz
Horizontal Viewing Angle
140
Vertical Viewing Angle
125
Backlight Technology
LED backlight
Controls & Adjustments
Mute, volume, brightness, contrast, H/V position, input select, colour temperature, phase, H-size
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Spanish, Japanese
4.8 kg
Audio
Speakers - stereo
Output Power / Channel
1 Watt
Input
Touch-screen - touchscreen
Movement Detection Technology
Resistive
DVI , VGA , Serial , USB
Mechanical
Tilt Angle
-5/+90
VESA Mounting Interface
100 x 100 mm
1 x VGA cable , 1 x DVI cable , 1 x serial cable , 1 x audio cable , 1 x USB cable
Security Slot Type
Kensington security slot
Input Voltage
Power Consumption (Typical)
20 Watt
Included Software
Driver
Microsoft Windows 95/98, Microsoft Windows CE, Linux, Apple MacOS 9, Microsoft Windows 2000 / NT4.0, Apple MacOS X, Microsoft Windows Vista / XP / 7
BV9L C2G 5m USB 2.0 A/B Cable - Black In Stock £5.07
