Product
iiyama ProLite T1531SAW-B3 15" 1024 x 768 8ms VGA DVI Touch Monitor
Quicklinx: CW3YWS00 Mfr#: T1531SAW-B3
Diagonal Size: 15in
Max Resolution: 1024 x 768
Response Time: 8ms
Speakers: Speaker(s)
Interfaces: DVI, VGA (HD-15)
£324.88 ex VAT
£389.85 inc VAT
The ProLite T1531SAW uses highly accurate surface acoustic wave touch technology (SAW) with a pure-glass scratch resistive front, offering superior image clarity and screen durability. The screen can be touched with a soft stylus, finger or gloved hand making it suitable for a number of applications, and the robust design and solid but flexible stand ensures resilience in demanding environments. Menu buttons are located on the side of the screen which can be locked to prevent tampering, and include a handy function to deactivate the touch screen for cleaning . The Iiyama Prolite T1531SAW1 touch screen is ideal for a wide range of applications including POS, kiosks, hospitality and entertainment, control rooms, education, training and many others.
  • Surface acoustic wave technology
    Surface acoustic wave technology offers great picture performance (high contrast and color accuracy).
  • Scratch resistance
    Scratch resistance is essential for touch solutions used in public places and schools. This is achieved thanks to a glass overlay covering the screen. It guarantees high durability of the touch function and even more importantly the touch function remains unaffected even if the glass is scratched.
  • Dust and water resistant
    The monitor will operate in dusty conditions, and will resist splashing water.
  • Speakers
    This LED monitor is equipped with two high quality stereo speakers.
  • VESA compliance
    VESA mount compliance means you can easily mount the LFD to any mounting that complies with the VESA standard.
iiyama ProLite T1531SAW-B3 - LED monitor - 15"
LED-backlit LCD monitor - 15" - touchscreen
Touch-screen
Panel Type
TN
Aspect Ratio
4:3
Native Resolution
1024 x 768
Pixel Pitch
0.297 mm
Contrast Ratio
700:1
Response Time
8 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Display Position Adjustments
Tilt
Screen Coating
8H Hard Coating
35.1 cm x 20.1 cm x 30.6 cm
4.8 kg
VCCI, DDC-2B, VESA DPMS, CB, cULus, IP54, TUV Bauart, CU
Display Type
Diagonal Size
15"
Panel Type
TN
Aspect Ratio
4:3
Native Resolution
1024 x 768
Pixel Pitch
0.297 mm
Brightness w/touchscreen
320 cd/m²
Contrast Ratio
700:1
Colour Support
Response Time
8 ms
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
31.5 - 60.2 kHz
Horizontal Viewing Angle
+85 / -85
Vertical Viewing Angle
+80 / -80
Screen Coating
8H Hard Coating
Backlight Technology
LED backlight
Controls & Adjustments
Mute, volume, brightness, contrast, H/V position, input select, colour temperature, phase, H-size
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Spanish, Japanese
Scratch-resistant
4.8 kg
Audio
Speakers - stereo
Output Power / Channel
1 Watt
Input
Touch-screen - touchscreen
Movement Detection Technology
VGA , DVI-D , USB , Serial , Audio line-in
Mechanical
Tilt
Tilt Angle
-5/+90
Flat Panel Mount Interface
100 x 100 mm
1 x VGA cable - VGA to VGA , 1 x DVI cable - DVI-D to DVI-D , 1 x audio cable , 1 x USB cable , 1 x serial cable
Security Slot Type
Kensington security slot
20 Watt
Power Consumption Stand by
3 Watt
Included Software
Drivers & Utilities
Microsoft Windows 95, Microsoft Windows 98, Microsoft Windows NT 4.0, Microsoft Windows CE, Linux, Apple MacOS 9, Apple MacOS X, FreeDOS, Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10
iiyama ProLite T1531SAW-B3 15 Bundle deal on iiyama ProLite T1531SAW-B3 15" 1024 x 768 8ms VGA DVI Touch Monitor
£424.64
Diagonal Size: 15in
Response Time: 8ms
Interfaces: DVI
Interfaces: VGA (HD-15)
Brand: iiyama
Price Range Ex VAT: 300 - 500
