iiyama ProLite T1531SAW-B1 15" 1024x768 8ms VGA DVI USB Touchscreen LCD Monitor
Quicklinx: B5CCWS00 Mfr#: T1531SAW-B1
The ProLite 1530S is based on the latest 5 Wire Resistive technology. Price/performance ratio is ideal for the budget conscious user while quality and specification is certainly not compromised. The display inputs include both Analog and Digital (DVI) with touchscreen connectivity via either USB or RS-232 which offers greater than typical flexibility. A solid and steady base supports the touchscreen with an adjustable stand offering full 90 degree angles. Extensive touch utilities allow for 4 point calibration and either 9/25 point linerization. The ProLite 1530S is an incredibly powerful touch solution.
iiyama ProLite T1531SAW-1 - LCD monitor - 15"
LCD monitor - 15" - touchscreen
Touch-screen, stereo speakers
Panel Type
TN
Aspect Ratio
4:3
Native Resolution
1024 x 768
Pixel Pitch
0.297 mm
Brightness
230 cd/m²
Contrast Ratio
500:1
Response Time
8 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
Tilt
Voltage
35.1 cm x 20.1 cm x 30.6 cm
4.8 kg
VCCI, DDC-2B, VESA DPMS, GOST-R, IP54, TUV Bauart
Display Type
LCD monitor / TFT active matrix
Diagonal Size
15"
Built-in Devices
Stereo speakers
Panel Type
TN
Aspect Ratio
4:3
Native Resolution
1024 x 768
Pixel Pitch
0.297 mm
Brightness
230 cd/m²
Contrast Ratio
500:1
Colour Support
Response Time
8 ms
Vertical Refresh Rate
75 Hz
Horizontal Refresh Rate
60.2 kHz
Horizontal Viewing Angle
140
Vertical Viewing Angle
125
Controls & Adjustments
Mute, volume, brightness, contrast, H/V position, input select, phase, H-size
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Spanish, Japanese
4.8 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
1 Watt
Input
Touch-screen - touchscreen
Movement Detection Technology
Surface acoustic wave
Serial , DVI-D , VGA , Audio line-in , USB
Mechanical
Tilt
Tilt Angle
95
VESA Mounting Interface
100 x 100 mm
1 x VGA cable , 1 x DVI cable - DVI-D to DVI-D , 1 x audio cable , 1 x serial cable , 1 x USB cable
Security Slot Type
Kensington security slot
Power Supply
External
Input Voltage
Power Consumption (Typical)
20 Watt
Power Consumption Stand by / Sleep
3 Watt
Included Software
Drivers & Utilities
B5CC C2G 5m USB 2.0 A/B Cable - Black In Stock £5.09
