The ProLite 1530S is based on the latest 5 Wire Resistive technology. Price/performance ratio is ideal for the budget conscious user while quality and specification is certainly not compromised. The display inputs include both Analog and Digital (DVI) with touchscreen connectivity via either USB or RS-232 which offers greater than typical flexibility. A solid and steady base supports the touchscreen with an adjustable stand offering full 90 degree angles. Extensive touch utilities allow for 4 point calibration and either 9/25 point linerization. The ProLite 1530S is an incredibly powerful touch solution.
- iiyama ProLite T1531SAW-1 - LCD monitor - 15"
- LCD monitor - 15" - touchscreen
- Touch-screen, stereo speakers
- Panel Type
- TN
- Aspect Ratio
- 4:3
- Native Resolution
- 1024 x 768
- Pixel Pitch
- 0.297 mm
- Brightness
- 230 cd/m²
- Contrast Ratio
- 500:1
- Response Time
- 8 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI-D, VGA
- Speakers
- Integrated
- Tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 35.1 cm x 20.1 cm x 30.6 cm
- 4.8 kg
- VCCI, DDC-2B, VESA DPMS, GOST-R, IP54, TUV Bauart
- Display Type
- LCD monitor / TFT active matrix
- Diagonal Size
- 15"
- Built-in Devices
- Stereo speakers
- Panel Type
- TN
- Aspect Ratio
- 4:3
- Native Resolution
- 1024 x 768
- Pixel Pitch
- 0.297 mm
- Brightness
- 230 cd/m²
- Contrast Ratio
- 500:1
- Colour Support
- Response Time
- 8 ms
- Vertical Refresh Rate
- 75 Hz
- Horizontal Refresh Rate
- 60.2 kHz
- Horizontal Viewing Angle
- 140
- Vertical Viewing Angle
- 125
- Controls & Adjustments
- Mute, volume, brightness, contrast, H/V position, input select, phase, H-size
- OSD Languages
- Chinese (traditional), Chinese (simplified), English, German, French, Italian, Spanish, Japanese
- Black
- 4.8 kg
Audio
- Speakers - stereo - integrated
- Output Power / Channel
- 1 Watt
Input
- Touch-screen - touchscreen
- Movement Detection Technology
- Surface acoustic wave
- Serial , DVI-D , VGA , Audio line-in , USB
Mechanical
- Tilt
- Tilt Angle
- 95
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable , 1 x DVI cable - DVI-D to DVI-D , 1 x audio cable , 1 x serial cable , 1 x USB cable
- Security Slot Type
- Kensington security slot
- Power Supply
- External
- Input Voltage
- Power Consumption (Typical)
- 20 Watt
- Power Consumption Stand by / Sleep
- 3 Watt
- Included Software
- Drivers & Utilities
