iiyama ProLite T1521MSC-B1 15" 1024 x 768 8ms VGA Touch Monitor
Quicklinx: CW3ZWS00 Mfr#: T1521MSC-B1
Diagonal Size: 15in
Max Resolution: 1024 x 768
Response Time: 8ms
Speakers: Speaker(s)
Interfaces: VGA (HD-15)
£252.09 ex VAT
£302.50 inc VAT
The ProLite T1521MSC-B1 15" touchscreen is based on projected capacitive technology, offering optimal seamless and accurate touch response. Due to its glass overlay, it guarantees high durability, scratch-resistance and perfect picture performance. A solid and steady base supports the touchscreen with an adjustable stand offering up to 80 degree tilt angles. Menu buttons are located on the back of the screen which can be locked to prevent tampering, and includes a handy function to deactivate the touchscreen for cleaning. The ProLite T1521MSC-B1 is an incredibly powerful touch solution, perfect for instore retail purposes.
  • Touch technology - capacitive
    This technology uses a sensor-grid of micro-fine wires integrated into the glass that covers the screen. Touch is detected because electrical characteristics of the sensor grid change when human finger is placed on the glass. Thanks to the glass overlay this technology is highly durable, and the touch function remains unaffected even if the glass is scratched. It offers perfect picture performance and will work with human finger (gloved or not) and magnetic ball.
  • IP54
    The IP Code classifies how resistant a device is to foreign objects and moisture. IP54 means that the monitor will operate in dusty conditions, and will resist splashing water.
  • Scratch resistance
    Scratch resistance is essential for touch solutions used in public places and schools. This is achieved thanks to a glass overlay covering the screen. It guarantees high durability of the touch function and even more importantly the touch function remains unaffected even if the glass is scratched.
  • VESA
    VESA mount compliance means you can easily mount the LFD to any mounting that complies with the VESA standard.
iiyama ProLite T1521MSC-B1 - LED monitor - 15"
LED-backlit LCD monitor - 15" - touchscreen
Energy Class
Class E
Power Consumption (On mode)
10.8 W
Touch-screen
Panel Type
TN
Aspect Ratio
4:3
Native Resolution
1024 x 768 at 75 Hz
Pixel Pitch
0.297 mm
Brightness
350 cd/m²
Contrast Ratio
800:1
Response Time
8 ms (black-to-white)
Colour Support
16.2 million colours
Input Connectors
VGA
Display Position Adjustments
Tilt
Screen Coating
7H Hard Coating
Voltage
34.05 cm x 19.8 cm x 30.8 cm
DDC-2B, VESA DPMS, CB, cULus, IP54, TUV Bauart
3-year warranty
Display Type
Energy Class
Class E
Diagonal Size
15"
Panel Type
TN
Aspect Ratio
4:3
Native Resolution
1024 x 768 at 75 Hz
Pixel Pitch
0.297 mm
Brightness
350 cd/m²
Brightness w/touchscreen
305 cd/m²
Contrast Ratio
800:1
Colour Support
Response Time
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
31.4 - 60 kHz
Horizontal Viewing Angle
+80 / -80
Vertical Viewing Angle
+80 / -80
Screen Coating
7H Hard Coating
Backlight Technology
LED backlight
Controls & Adjustments
Mute, volume, brightness, contrast, H/V position, sharpness, colour temperature, phase, clock
OSD Languages
English, German, French, Italian, Polish, Russian, Spanish, Dutch
HID Compliant, scratch-resistant, a-Si technology
34.05 cm x 19.8 cm x 30.8 cm - with stand
Audio
Speakers - stereo
Output Power / Channel
2 Watt
Input
Touch-screen - touchscreen
Movement Detection Technology
Projected capacitive
VGA , USB , Audio line-in (mini-jack)
Mechanical
Tilt
Tilt Angle
-10/+70
VESA Mounting Interface
75 x 75 mm
1 x VGA cable , 1 x USB cable
Input Voltage
10.8 W
10.8 kWh/1000h
Power Consumption (Typical)
20 Watt
Power Consumption Stand by
0.5 Watt
Linux, Microsoft Windows Vista / XP / 7 / 8, Windows 10
Dimensions & Weight Details
Without stand - width: 34.05 cm - depth: 4.45 cm - height: 26.8 cm , With stand - width: 34.05 cm
Limited warranty - 3 years
20 - 80% (non-condensing)
Diagonal Size: 15in
Response Time: 8ms
Brand: iiyama
Stock Status: While stocks last
Stock Status: Clearance
