Give your sales promotions and your in-store displays maximum impact and visibility with the ProLite S3820HSB-B1. The S3820HSB is a 38" (1920x540) digital signage display that is ideally suited for retail, transportation, business and health care environments where a regular 16:9 display will not fit.
With a 24/7 operating time, landscape and portrait orientation and brightness of 1000cd/m2, this display can be installed anyhow and anywhere you want, ensuring an optimal fit and maximum exposure. The S3820HSB is fanless, only weighs 8.8 kg and comes with two handles for easy handling and installation.
- iiyama ProLite S3820HSB-B1 38" LED-backlit LCD display - Full HD - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 38"
- Commercial Use
- Yes - digital signage
- Matte black
- Resolution
- 1920 x 540
- Display Format
- 1080i
- Frame Rate & Enhancement Technology
- 60 Hz Frame Rate
- Video Interface
- HDMI
- PC Interface
- DVI, VGA (HD-15)
- Technology
- AMVA3
- LCD Backlight Technology
- LED backlight
- Image Aspect Ratio
- 16:4.5
- TV Tuner
- No tuner
- Speaker System
- 2 speakers
- Voltage
- AC 120/230 V (50 - 60 Hz)
- Energy Class
- Class B
- 42.5 Watt
- Power Consumption Stand by
- 0.5 Watt
- 96.3 cm x 5.42 cm x 30.5 cm
- 8.8 kg
- Product Type
- Energy Class
- Class B
- 42.5 Watt
- Diagonal Class
- 38"
- Commercial Use
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Sensors
- Light sensor
- Video Interface
- HDMI
- PC Interface
- DVI, VGA (HD-15)
- Modes
- Portrait mode, landscape mode
- Design
- Fanless Design
- 96.3 cm
- 5.42 cm
- 30.5 cm
- 8.8 kg
- Enclosure Colour
- Matte black
Display
- LCD Display Technology
- AMVA3
- Resolution
- 1920 x 540
- Display Format
- 1080i
- 16:4.5
- 60 Hz Frame Rate
- LED backlight
- Image Contrast Ratio
- 4000:1
- Brightness
- 1000 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Response Time
- 8 ms
- Display Menu Language
- English
- Backlight Life
- 100,000 hour(s)
- Operation Hours / Days
- 24 / 7
Stands & Mounts
- Flat Panel Mount Interface
- 400 x 100 mm
- VESA Compatibility
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 10 Watt
- Speakers
- 2 x main channel speaker - 5 Watt
- Connector Type
- VGA input , DVI-D input , HDMI input , Audio output , RS-232C input , RS-232C output
- Cables Included
- HDMI cable - 1.8 m , Serial cable , Sensor cable
- DDC-2B, CB, CU, REACH SvHC
- Power Device
- Power supply
- Input Voltage
- 0.5 Watt
- 0.5 Watt
- 0 °C
- 50 °C
