iiyama ProLite P2252HS-B1 22" 1920x1080 5ms HDMI DVI-D LED Black Monitor with Speakers
Quicklinx: 8W95WS00 Mfr#: P2252HS-B1
Diagonal Size: 22in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: DVI, HDMI, VGA (HD-15)
10 in stock
£106.43 ex VAT
£127.71 inc VAT
This high quality LCD monitor has a toughened safety glass fitted behind the bezel. It offers hardness rating, capable of resisting above normal pressure and impacts to the display. The high end LCD panel with LED backlights not only reduces the power consumption it also offers a bright image with high contrast.
  • LED-backlit
    A typical CCFL LCD uses four backlight lamps. Using LED diodes considerably lowers the power consumption and reduces the CO2 emission into the environment making this LCD a true eco-friendly product.
  • ACR
    Contrast Ratio is a measurement of this difference between the blackest black and the whitest white your LCD can display. Advanced Contrast Ratio is a feature that automatically adjusts the contrast and brightness based on the darkness of the image. The higher the ratio, the better your screen will look when you have the lights off in a room.
  • HDMI
    HDMI stands for high-definition multimedia interface. Much smaller and more convenient than DVI, HDMI also has the significant advantage over DVI that it supports audio as well as video signals.
  • VESA
    VESA mount compliance means you can easily mount your monitor to a wall.
  • FULL HD
    With true resolution your LCD is ready to display any high definition images. It also offers you much more viewable area than a standard LCD.
  • Speakers
    This LED monitor is equipped with two high quality stereo speakers.
iiyama ProLite P2252HS-B1 - LED monitor - Full HD (1080p) - 22"
LED-backlit LCD monitor - 22"
Energy Class
Class A
Energy Consumption per Year
29 kWh
Power Consumption (On mode)
20.1 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.248 mm
Brightness
225 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
Tilt
Screen Coating
8H Hard Coating
51.65 cm x 19.5 cm x 38.25 cm
4.5 kg
Environmental Standards
ENERGY STAR Qualified
DDC-2B, VESA DPMS, PSE Mark, TUV Bauart, VCCI Class B
Display Type
Energy Class
Class A
29 kWh
Diagonal Size
22"
Viewable Size
21.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
225 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
24 - 80 kHz
Horizontal Viewing Angle
+85 / -85
Vertical Viewing Angle
+80 / -80
Screen Coating
8H Hard Coating
Backlight Technology
LED backlight
Controls & Adjustments
Mute, volume, brightness, contrast, H/V position, sharpness, input select, phase, clock
OSD Languages
English, German, French, Polish, Russian, Dutch, Japanese, Chinese
HDCP, Advanced Contrast Ratio (ACR)
4.5 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
1 Watt
VGA , DVI-D , HDMI , Headphones
Mechanical
Tilt
Tilt Angle
20
VESA Mounting Interface
100 x 100 mm
1 x VGA cable , 1 x DVI cable , 1 x audio cable
Power Supply
Internal
20.1 W
18 Watt
Power Consumption Stand by
0.5 Watt
Included Software
Driver
Apple MacOS, Microsoft Windows 95/98/ME/2000/XP, Microsoft Windows Vista / 7 / 8
ENERGY STAR Certified
8W95 C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
8W95 C2G 5m Select High Speed HDMI with Ethernet In Stock £20.51
8W95 C2G 15m Select High Speed HDMI with Ethernet In Stock £53.35
Diagonal Size: 22in
Response Time: 5ms
Interfaces: DVI
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: iiyama
Price Range Ex VAT: 100 - 150
