Product
Brand
iiyama ProLite LH6564S-B1 65" 1920x1080 8ms VGA DVI HDMI LED Large Format Display
Quicklinx: B1K6WS00 Mfr#: LH6564S-B1
  • 1080p (Full HD)
Incorporating AMVA3 panel technology the LH6564S guarantees great viewing from all angles, high brightness and perfect color clarity. It features an ambient light sensor delivering exceptional performance with the added benefit of saving on power. Features include PIP and PBP perfect for video conferencing or handing multi-input content in many environments. Perfect for true impact in Digital Signage.
Iiyama ProLite LH6564S-B1 65" Class (65" viewable) LED display
LED-backlit LCD flat panel display
Diagonal Class
65"
Diagonal Size
65 in
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Video Interface
Component, composite, HDMI, S-Video
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
AMV3
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
Remote Control
Standard remote
Voltage
Energy Class
Class B
250 Watt
Power Consumption (On mode)
179.2 W
Energy Consumption per Year
262 kWh
151.15 cm x 9.05 cm x 88.15 cm
47.7 kg
Energy Class
Class B
250 Watt
179.2 W
262 kWh
Diagonal Class
65"
Diagonal Size
65 in
Commercial Use
TV Tuner
No tuner
Sensors
Ambient light sensor (ALS)
Video Interface
HDMI Ports Qty
1 ports
PC Interface
HDCP Compatible
Modes
Portrait mode, landscape mode
151.15 cm
9.05 cm
88.15 cm
47.7 kg
Enclosure Colour
Display
LCD Display Technology
AMV3
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
LED backlight
Colour Depth
Up to 1.07 billion colours
Image Contrast Ratio
4000:1
Brightness
450 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.744 x 0.744mm
Response Time
8 ms
Display Menu Language
English, German, French, Polish, Russian, Spanish, Dutch
Colour Temperature Control
Stands & Mounts
Flat Panel Mount Interface
400 x 400 mm
Remote Control
Standard remote
Audio System
Audio Controls
Sound mode, balance, bass, treble
Speaker System
2 speakers
Output Power / Total
24 Watt
Speakers
2 x main channel speaker - built-in - 12 Watt
Connector Type
VGA input , S-Video input , Composite video input , Audio line-in , Audio line-in , HDMI input , Audio line-out , Component video input , Network , Serial output , Serial input , DVI-D input , USB , Composite video output , VGA output , DisplayPort input
VGA cable , DVI cable
DDC-2B, VESA DPMS, CB, TUV Bauart
Power supply
Nominal Voltage
Power Consumption Stand by
0.5 Watt
