As the screen is covered with a glass layer, this technology offers great picture performance (high contrast and color accuracy) and scratch-resistance making it the ideal choice for use in public areas. Moreover, even if the screen is scratched, the touch function remains unaffected. Surface Acoustic Touchscreens are activated with finger or a special stylus.
The resistive touchscreens work with both finger and any input device which guarantees high accuracy level. The 5 wire resistive screens, do not lose calibration over time. Durable, robust design and an IP54 rated housing allow for installation in any kind of environment including industrial areas and retail.
Surface acoustic wave - single-touch solutions
As the screen is covered with a glass layer, this technology offers great picture performance (high contrast and color accuracy) and scratch-resistance making it the ideal choice for use in public areas. Moreover, even if the screen is scratched, the touch function remains unaffected. Surface Acoustic Touchscreens are activated with finger or a special stylus. -
Resistive - single-touch solutions
The resistive touchscreens work with both finger and any input device which guarantees high accuracy level. The 5 wire resistive screens, do not lose calibration over time. Durable, robust design and an IP54 rated housing allow for installation in any kind of environment including industrial areas and retail. -
Optical - multi-touch solutions
The optical touch technology does not rely on an overlay or substrate to register a touch event, so it's impossible to physically "wear out" the touchscreen. In fact you don't really have to physically touch the screen. You just need to put your finger or any kind of stylus very close to it. The optical technology ensures great picture performance. As there is no overlay or substrate on the screen the display characteristics remain virtually unaffected by the touch function. -
Projected capacitive - multi-touch solutions
Thanks to the glass overlay this technology is highly durable and the touch function remains unaffected even if the glass is scratched.
- iiyama ProLite LH5565S-B1 55" Class (54.6" viewable) LED-backlit LCD display - Full HD - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 55"
- Diagonal Size
- 54.6"
- Commercial Use
- Yes - digital signage
- Black
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Video Interface
- Component, HDMI
- HDMI Ports Qty
- 3 ports
- Connectivity
- LAN
- PC Interface
- VGA (HD-15)
- Technology
- IPS
- LCD Backlight Technology
- LED backlight
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Speaker System
- 2 speakers
- USB
- Included Accessories
- Remote control, cable ties, sticker, 2 batteries
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class A
- 105 Watt
- Power Consumption Stand by
- 0.5 Watt
- Dimensions (WxDxH) - without stand
- 124.75 cm x 5.35 cm x 71.8 cm
- 26.3 kg
- Product Type
- Energy Class
- Class A
- 105 Watt
- Diagonal Class
- 55"
- Diagonal Size
- 54.6"
- Commercial Use
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Sensors
- Ambient light sensor (ALS)
- Video Interface
- Component, HDMI
- HDMI Ports Qty
- 3 ports
- PC Interface
- VGA (HD-15)
- Modes
- Portrait mode, landscape mode
- Design
- Fanless Design
- Dimensions
- Without stand
- 124.75 cm
- 5.35 cm
- 71.8 cm
- 26.3 kg
- Enclosure Colour
- Black
Display
- LCD Display Technology
- IPS
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- 16:9
- LED backlight
- Image Contrast Ratio
- 1100:1
- Brightness
- 450 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Response Time
- 12 ms
- Display Menu Language
- Czech, English, German, French, Italian, Polish, Russian, Japanese
- Daisy Chain
Stands & Mounts
- Flat Panel Mount Interface
- 400 x 400 mm
Media Player
- USB Port
- USB Ports Qty
- 1
Remote Control
- Remote control
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Speakers
- 2 x speaker - 10 Watt
Network & Internet Multimedia
- Connectivity
- LAN
- Connector Type
- VGA input , Component video input , USB , 3 x HDMI input , HDMI output , Component video output , Audio line-in , Audio input , Audio line-out , Remote control , LAN , Infrared (IrDA)
- Cable ties, sticker, 2 batteries
- Cables Included
- VGA cable , HDMI cable
- DDC-2B, VESA DPMS
- Power Device
- Power supply
- Input Voltage
- 0.5 Watt
