AMVA3
AMVA3 technology offers higher contrast, darker blacks and much better viewing angles than standard TN technology. The screen will look good no matter what angle you look at it. -
4K
UHD resolution (3840x2160), better known as 4K, offers a gigantic viewable area with 4 times more information and work space than a Full HD screen. Due to the high DPI (dots per inch), it displays an incredibly sharp and crisp image. -
DisplayPort/HDMI daisy chain support
A daisy chain is a wiring scheme in which multiple devices are wired together in sequence or in a ring. It enables a connection of a series of devices using a single connection between each two devices, using DisplayPort/HDMI input and a DisplayPort/HDMI output. The output connects to the next downstream display. This cabling arrangement, with one DisplayPort/HDMI cable between each set of monitors, provides a simple, less cluttered system configuration. -
Light sensor
The ambient light sensor detects changes in environmental lighting conditions and automatically adjusts the screens backlight brightness to compensate for an increase or decrease in light.
- iiyama ProLite LH5550UHS-B1 55" LED-backlit LCD display - 4K - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 55"
- Commercial Use
- Yes - digital signage
- Matte black
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- Video Interface
- Component, HDMI
- HDMI Ports Qty
- 3 ports
- Connectivity
- LAN
- PC Interface
- HDMI, DisplayPort, serial RS-232
- Technology
- AMVA3
- LCD Backlight Technology
- LED backlight
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Speaker System
- 2 speakers
- USB
- 3 ports
- Included Accessories
- Remote control, 4 screws, batteries, mini-PC bracket
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class C
- 160 Watt
- Power Consumption (On mode)
- 184 W
- Power Consumption Stand by
- 0.5 Watt
- Energy Consumption per Year
- 270 kWh
- Dimensions (WxDxH) - without stand
- 124.5 cm x 6.9 cm x 71.85 cm
- 16.8 kg
- Product Type
- Energy Class
- Class C
- 160 Watt
- 184 W
- 270 kWh
- Diagonal Class
- 55"
- Commercial Use
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Sensors
- Ambient light sensor (ALS)
- Video Interface
- Component, HDMI
- HDMI Ports Qty
- 3 ports
- PC Interface
- Modes
- Portrait mode, landscape mode
- Design
- Fanless Design
- Dimensions
- Without stand
- 124.5 cm
- 6.9 cm
- 71.85 cm
- 16.8 kg
- Enclosure Colour
- Matte black
Display
- LCD Display Technology
- AMVA3
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- 16:9
- LED backlight
- Image Contrast Ratio
- 4000:1
- Brightness
- 450 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Response Time
- 8 ms
- Display Menu Language
- Czech, English, German, French, Italian, Polish, Russian, Spanish, Dutch, Japanese, Chinese
- Daisy Chain
Stands & Mounts
- Flat Panel Mount Interface
- 400 x 400 mm
Media Player
- USB Port
- USB Ports Qty
- 3
Remote Control
- Remote control
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Speakers
- 2 x speaker - 10 Watt
Network & Internet Multimedia
- Functionality
- Streaming media playback
- Connectivity
- LAN
- Connector Type
- 3 x component video input , 3 x HDMI input , DisplayPort input , Audio input , RS-232 input , LAN , Infrared input , Daisy chain output , Audio output , 2 x audio output , RS-232 output , USB 3.0 , 2 x USB 2.0
- 4 screws, batteries, mini-PC bracket
- Cables Included
- HDMI cable - 1.8 m , DisplayPort cable - 1.8 m
- Plug and Play, DDC-2B, CB, TUV Bauart, CU, DisplayPort 1.2
- Power Device
- Power supply
- Input Voltage
- 0.5 Watt
- Width (Shipping)
- 142.3 cm
- Depth (Shipping)
- 22.6 cm
- Height (Shipping)
- 86.3 cm
- Weight (Shipping)
- 23.7 kg
- 0 °C
- 40 °C
