Product
iiyama ProLite LH5550UHS-B1 55" 3840x2160 LED Digital Signage
Quicklinx: DKJWWS00 Mfr#: LH5550UHS-B1
£1,097.89 ex VAT
£1,317.46 inc VAT
Marketing description is not available.
  • AMVA3
    AMVA3 technology offers higher contrast, darker blacks and much better viewing angles than standard TN technology. The screen will look good no matter what angle you look at it.
  • 4K
    UHD resolution (3840x2160), better known as 4K, offers a gigantic viewable area with 4 times more information and work space than a Full HD screen. Due to the high DPI (dots per inch), it displays an incredibly sharp and crisp image.
  • DisplayPort/HDMI daisy chain support
    A daisy chain is a wiring scheme in which multiple devices are wired together in sequence or in a ring. It enables a connection of a series of devices using a single connection between each two devices, using DisplayPort/HDMI input and a DisplayPort/HDMI output. The output connects to the next downstream display. This cabling arrangement, with one DisplayPort/HDMI cable between each set of monitors, provides a simple, less cluttered system configuration.
  • Light sensor
    The ambient light sensor detects changes in environmental lighting conditions and automatically adjusts the screens backlight brightness to compensate for an increase or decrease in light.
iiyama ProLite LH5550UHS-B1 55" Class (55" viewable) LED display
LED-backlit LCD flat panel display
Diagonal Class
55"
Diagonal Size
55 in
Commercial Use
Yes - digital signage
Matte black
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Video Interface
Component, HDMI
HDMI Ports Qty
3 ports
LAN
PC Interface
HDMI, DisplayPort, serial RS-232
AMVA3
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
USB
3 ports
Remote Control
Standard remote
Voltage
Energy Class
Class C
160 Watt
Power Consumption (On mode)
184 W
Energy Consumption per Year
270 kWh
124.5 cm x 6.9 cm x 71.85 cm
16.8 kg
Energy Class
Class C
160 Watt
184 W
270 kWh
Diagonal Class
55"
Diagonal Size
55 in
Commercial Use
TV Tuner
No tuner
TV Tuner Presence
No
Sensors
Ambient light sensor (ALS)
Video Interface
Component, HDMI
HDMI Ports Qty
3 ports
PC Interface
Modes
Portrait mode, landscape mode
Design
Fanless Design
Dimensions
Without stand
124.5 cm
6.9 cm
71.85 cm
16.8 kg
Enclosure Colour
Matte black
Display
LCD Display Technology
AMVA3
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Image Aspect Ratio
16:9
LED backlight
Image Contrast Ratio
4000:1
Brightness
450 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
8 ms
Display Menu Language
Czech, English, German, French, Italian, Polish, Russian, Spanish, Dutch, Japanese, Chinese
Daisy Chain
Stands & Mounts
Flat Panel Mount Interface
400 x 400 mm
Media Player
USB Port
USB Ports Qty
3
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x speaker - built-in - 10 Watt
Network & Internet Multimedia
Functionality
Streaming media playback
LAN
Connector Type
3 x component video input , 3 x HDMI input , DisplayPort input , Audio input , RS-232 input , LAN , Infrared input , Daisy chain output , Audio output , 2 x audio output , RS-232 output , USB 3.0 , 2 x USB 2.0
4 screws, batteries, mini-PC bracket
HDMI cable - 1.8 m , DisplayPort cable - 1.8 m
Plug and Play, DDC-2B, CB, TUV Bauart, CU, DisplayPort 1.2
Power supply
Nominal Voltage
Power Consumption Stand by
0.5 Watt
Width (Shipping)
142.3 cm
Depth (Shipping)
22.6 cm
Height (Shipping)
86.3 cm
Weight (Shipping)
23.7 kg
Brand: iiyama
Price Range Ex VAT: 1000 - 1500
