iiyama ProLite LH4982SB-B1 49" 1920x1080 8ms VGA DVI HDMI DisplayPort LED Large Format Display
Quicklinx: DVMFWS00 Mfr#: LH4982SB-B1
TV Tuner Presence: No
Video Interface: Component, HDMI
  • 1080p (Full HD)
11 in stock
£885.88 ex VAT
£1,063.05 inc VAT
The ProLite professional large format display is the ideal digital signage solution for companies that want maximum impact and maximum flexibility. The slim design and ultra-thin metal bezel combined with the high-brightness IPS panel, 24/7 operating time and landscape/portrait orientation ensures optimal fit in almost any digital signage set-up, incl. video walls. The LED-backlit technology guarantees low power consumption and together with the active cooling ensures a reliable long-term operation. It can be operated via LAN network, RS232 or via an OPS plug-in PC.
  • IPS technology
    IPS technology offers higher contrast, darker blacks and much better viewing angles than standard TN technology. The screen will look good no matter what angle you look at it.
  • OPS PC slot
    Build in expansion slot supports the Open Pluggable Specification (OPS) standard; it simplifies the installation of a plug-in PC for digital signage applications.
  • DisplayPort/HDMI daisy chain support
    A daisy chain is a wiring scheme in which multiple devices are wired together in sequence or in a ring. It enables a connection of a series of devices using a single connection between each two devices, using DisplayPort/HDMI input and a DisplayPort/HDMI output. The output connects to the next downstream display. This cabling arrangement, with one DisplayPort/HDMI cable between each set of monitors, provides a simple, less cluttered system configuration.
  • LAN control
    LAN control enables making adjustments in the display OSD menu through your network.
iiyama ProLite LH4982SB-B1 49" Class (48.5" viewable) LED display
LED-backlit LCD flat panel display
Diagonal Class
49"
Diagonal Size
48.5"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Video Interface
Component, HDMI
HDMI Ports Qty
2 ports
LAN
PC Interface
DVI, VGA (HD-15), DisplayPort
IPS
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Picture Enhancements
Digital Crystal Clear, Noise Reduction, MPEG artifact reduction
Speaker System
2 speakers
USB
Remote Control
Standard remote
Voltage
Energy Class
Class C
135 Watt
Power Consumption (On mode)
134.8 W
Power Consumption Stand by
0.5 Watt
Energy Consumption per Year
197 kWh
109.3 cm x 7.1 cm x 62.3 cm
19 kg
Energy Class
Class C
135 Watt
134.8 W
197 kWh
Diagonal Class
49"
Diagonal Size
48.5"
Commercial Use
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
Component, HDMI
HDMI Ports Qty
2 ports
PC Interface
Modes
Portrait mode, landscape mode
Dimensions
Without stand
109.3 cm
7.1 cm
62.3 cm
19 kg
Enclosure Colour
Display
LCD Display Technology
IPS
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
LED backlight
Image Contrast Ratio
1300:1
Brightness
700 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
8 ms
Display Menu Language
Czech, English, German, French, Italian, Portuguese, Russian, Spanish, Dutch, Turkish, Arabic, Japanese, Chinese
Open Pluggable Specification slot, Daisy Chain, sleep timer
Stands & Mounts
VESA Mounting Interface
400 x 400 mm
Media Player
USB Port
USB Ports Qty
1
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x speaker - built-in - 10 Watt
Network & Internet Multimedia
LAN
Connector Type
VGA input , Component video input , Component video input , DVI-D input , 2 x HDMI input , DisplayPort input , DVI-D output , DisplayPort output , Audio input , Audio input , Audio output , Audio output , 2 x speakers output , Serial input , Serial output , LAN , Infrared input , Infrared output , USB 2.0
2 batteries
DVI cable , HDMI cable , Mini DisplayPort-DisplayPort cable , DisplayPort cable , Serial cable
Plug and Play, DDC-2B, VESA DPMS, CB, TUV Bauart, DisplayPort 1.2
Power supply
Nominal Voltage
0.5 Watt
On / Off Switch
20 - 80% (non-condensing)
Video Interface: HDMI
Brand: iiyama
Price Range Ex VAT: 750 - 1000
