iiyama Prolite LH4981S-B1 49" DVI VGA HDMI Commercial Display
Quicklinx: CB0NWS00 Mfr#: LH4981S-B1
  • 1080p
The professional appearance of the ProLite LH4981S incorporates a slim design featuring a sleek bezel. Featuring IPS panel technology this elegant display ensures amazing color accuracy and vivid, life-like quality from all angles. The LED-backlit technology provides low power consumption and reliable long-term operation. Built-in expansion slot supports the Open Pluggable Specification (OPS) standard, it simplifies the installation of a plug-in PC for digital signage applications. Landscape and Portrait friendly, ProLite LH4981S is designed for a continues operation. Perfect for true impact in Digital Signage and an ideal solution for a video wall set-up.
  • IPS technology
    IPS technology offers higher contrast, darker blacks and much better viewing angles than standard TN technology. The screen will look good no matter what angle you look at it.
  • OPS PC slot
    Build-in expansion slot supports the Open Pluggable Specification (OPS) standard, it simplifies the installation of a plug-in PC for digital signage applications.
  • Ultra Slim Line
    Ultra Slim Line monitors feature a sleek bezel and are therefore particularly suitable for video wall or a multi-monitor set-up.
  • USB playback
    The monitor supports playback of presentations, video and almost any type of content stored on the USB device or internal memory.
  • LAN control
    LAN control enables making adjustments in the display OSD menu through a web interface or threads.
iiyama ProLite LH4981S-B1 49" Class (48.5" viewable) LED-backlit LCD display - Full HD - for digital signage
LED-backlit LCD flat panel display
Diagonal Class
49"
Diagonal Size
48.5"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p
Video Interface
Component, HDMI
HDMI Ports Qty
2 ports
PC Interface
DVI, VGA (HD-15), DisplayPort
IPS
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
USB
Remote control
Voltage
Energy Class
Class C
135 Watt
Power Consumption (On mode)
132.7 W
Power Consumption Stand by
0.5 Watt
Energy Consumption per Year
194 kWh
109.3 cm x 7.1 cm x 62.3 cm
19 kg
Energy Class
Class C
135 Watt
132.7 W
194 kWh
Diagonal Class
49"
Diagonal Size
48.5"
Commercial Use
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
Component, HDMI
HDMI Ports Qty
2 ports
PC Interface
Modes
Portrait mode, landscape mode
Design
Fanless Design
109.3 cm
7.1 cm
62.3 cm
19 kg
Enclosure Colour
Display
LCD Display Technology
IPS
Resolution
1920 x 1080
Display Format
1080p
Image Aspect Ratio
16:9
LED backlight
Image Contrast Ratio
1300:1
Brightness
500 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
8 ms
Display Menu Language
Czech, English, German, French, Italian, Portuguese, Polish, Russian, Spanish, Dutch, Turkish, Arabic, Japanese, Chinese
MPEG artifact reduction, Open Pluggable Specification slot, security lock slot (cable lock sold separately), Noise Reduction, remote lock
Stands & Mounts
Flat Panel Mount Interface
400 x 400 mm
Media Player
USB Port
USB Ports Qty
1
Remote Control
Remote control
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
External Speakers Amplifier Power (Total)
20 Watt
Speakers
2 x speaker - 10 Watt
Connector Type
2 x HDMI , 2 x DisplayPort , DVI-D input , DVI-D output , VGA input , Component video input , Audio input , Serial input , Serial output , Remote control input , Remote control output , LAN , Audio input , Audio output , USB 2.0 , 2 x speakers output , Audio output
DVI cable , HDMI cable , Mini DisplayPort-DisplayPort cable , DisplayPort cable , Serial cable
DDC-2B, VESA DPMS, CB, TUV Bauart
Power supply
Input Voltage
0.5 Watt
20 - 80% (non-condensing)
