iiyama ProLite LH4946HS-B1 49" 1920x1080 12ms VGA DVI HDMI LED Large Format Display
Quicklinx: F7RYWS00 Mfr#: LH4946HS-B1
TV Tuner Presence: No
Video Interface: HDMI
  • 1080p (Full HD)
£642.35 ex VAT
£770.82 inc VAT
The ProLite merges the versatility and freedom of an Android OS display with the flexibility of a landscape and portrait orientation to bring you a well-rounded digital signage display you can easily customize to your needs by installing applications directly to it. It features an IPS panel, Full HD resolution, a continuous 24/7 operating time, a media player and a full range of connectors - VGA, DVI, HDMI and DisplayPort. Daisy Chain function makes the screen suitable for use in a wide variety of environments and set-ups including video walls.
  • Daisy chain support
    Daisy chain is a connection scheme in which several devices are connected in sequence or in a ring. It enables a connection of a series of devices using a single connection between each two devices via a cable. The signal output is connected to the signal input of the next device. The connection with only one cable between two devices ensures a simple and tidy installation.
  • IPS
    IPS technology offers higher contrast, darker blacks and much better viewing angles than standard TN technology. The screen will look good no matter what angle you look at it.
  • 24/7
    24/7 displays are designed for a continuous operation.
  • Media player LFD
    Play your favorite music and show your most beautiful videos, photos and images directly on screen from a flash drive or internal memory with the built-in media player.
iiyama ProLite LH4946HS-B1 49" Class (48.5" viewable) LED display
LED-backlit LCD flat panel display
Diagonal Class
49"
Diagonal Size
48.5"
Commercial Use
Yes - digital signage
Matte black
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Video Interface
HDMI
HDMI Ports Qty
2 ports
LAN
PC Interface
DVI, VGA (HD-15), DisplayPort
IPS
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
Supported Memory Cards
microSD
USB
Remote Control
Standard remote
Voltage
Energy Class
Class A+
65.7 Watt
Power Consumption Stand by
0.5 Watt
109.76 cm x 4.55 cm x 63.39 cm
15.6 kg
Energy Class
Class A+
65.7 Watt
Diagonal Class
49"
Diagonal Size
48.5"
Commercial Use
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
HDMI
HDMI Ports Qty
2 ports
PC Interface
Modes
Portrait mode, landscape mode
Design
Fanless Design, Thin Bezel Design
109.76 cm
4.55 cm
63.39 cm
15.6 kg
Enclosure Colour
Matte black
Display
LCD Display Technology
IPS
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
LED backlight
Image Contrast Ratio
1100:1
Brightness
450 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
12 ms
Display Menu Language
English, German, French, Italian, Polish, Russian, Spanish, Japanese, Chinese
Backlight Life
50,000 hour(s)
Anti-image retention, Daisy Chain, picture in picture (no tuner), designed for 24/7 operation
Stands & Mounts
VESA Mounting Interface
400 x 400 mm
Media Player
microSD
USB Port
USB Ports Qty
1
Operating System
Android OS
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - built-in - 10 Watt
Network & Internet Multimedia
LAN
Connector Type
VGA input , DVI-D input , 2 x HDMI input , DisplayPort input , RS-232 input , Network , Infrared input , Audio input , Audio output , DVI-D output , DisplayPort output , Speakers output , RS-232C output , USB 2.0
HDMI cable , Mini DisplayPort-DisplayPort cable , DisplayPort cable , DVI cable , Serial cable
Plug and Play, DDC-2B, CB, REACH, TUV Bauart, CU
Power supply
Nominal Voltage
0.5 Watt
Width (Shipping)
129.2 cm
Depth (Shipping)
20.3 cm
Height (Shipping)
88.3 cm
Brand: iiyama
Price Range Ex VAT: 500 - 750
