Your basket is empty
iiyama ProLite LH4780SB 47" 1920x1080 VGA DVI-D HDMI LED Large Format Display
Quicklinx: 99N4WS00 Mfr#: LH4780SB-B1
  • 1080p (Full HD)
Full HD professional, feature-rich and robust, Iiyama's large format screen is designed in 47" sizes and with or without multi-touch functionality. The displays offer an exceptional capacity within retail, education, training, corporate and B2B markets. Incorporating the IPS panel technology, the display guarantee high brightness, exceptional color clarity and great viewing from all angles. Features include PIP and PBP perfect for video conferencing or handing multi-input content in many environments. An ambient light sensor delivers exceptional performance with the added benefit of saving on power. Landscape and portrait friendly, the display can be mounted according to the application for true impact in interactive digital signage.
Iiyama ProLite LH4780SB-1 47" LED display
LED-backlit LCD flat panel display
Diagonal Class
47"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Video Interface
Component, composite, HDMI, S-Video
HDMI Ports Qty
2 ports
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
IPS
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
Remote Control
Standard remote
Voltage
Energy Class
Class B
140 Watt
Power Consumption (On mode)
85.4 W
Energy Consumption per Year
125 kWh
108 cm x 4.65 cm x 62.45 cm
17 kg
Environmental Standards
ENERGY STAR Qualified
Energy Class
Class B
140 Watt
85.4 W
125 kWh
Diagonal Class
47"
Commercial Use
TV Tuner
No tuner
Sensors
Ambient light sensor (ALS)
Video Interface
HDMI Ports Qty
2 ports
PC Interface
HDCP Compatible
Modes
Portrait mode, landscape mode
108 cm
4.65 cm
62.45 cm
17 kg
Enclosure Colour
Display
LCD Display Technology
IPS
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
LED backlight
Colour Depth
Up to 1.06 billion colours
Image Contrast Ratio
1300:1
Brightness
700 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.542 x 0.542mm
Response Time
12 ms
Display Menu Language
English, German, French, Polish, Russian, Dutch
Colour Temperature Control
Open Pluggable Specification slot
Stands & Mounts
Flat Panel Mount Interface
400 x 400 mm
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x speaker - built-in - 10 Watt
Connector Type
VGA / component video input , S-Video input , Composite video input , Audio line-in , DVI-D input , 2 x HDMI input , DisplayPort input , Audio output , Speakers output , Composite video output , Network , Serial output , Serial input , DVI-D output , 2 x USB 2.0 , USB 2.0
VGA cable , DVI cable
DDC-2B, VESA DPMS, CB, TUV Bauart
ENERGY STAR Certified
Power supply
Nominal Voltage
Power Consumption Stand by
0.8 Watt
