Product
iiyama ProLite LH4664S-1 46" 1920 x 1080 6.5ms VGA Commercial LED
Quicklinx: CR11WS00 Mfr#: LH4664S-B1
  • 1080p (Full HD)
Incorporating AMVA3 panel technology the LH4664S guarantees great viewing from all angles, high brightness and perfect color clarity. It features an ambient light sensor delivering exceptional performance with the added benefit of saving on power. Features include PIP and PBP perfect for video conferencing or handing multi-input content in many environments. Landscape and portrait friendly, the display can be mounted according to the application for true impact in digital signage.
  • Full HD
    With true 1920 x 1080p resolution this LFD is ready to display high definition images. This means it can accommodate more information on the screen; e.g. 60% more in comparison to a 1280 x 1024 monitor.
  • Multiple inputs
    A wide range of video inputs assures compatibility with multiple platforms.
  • AMVA3
    AMVA3 Panel technology offers 24 bit "true color" performance and amazing viewing angles.
  • Light sensor
    The ambient light sensor detects changes in environmental lighting conditions and automatically adjusts the screens backlight brightness to compensate for and increase or decrease in light.
  • PIP
    PIP (picture in picture) function allows you to watch images coming from two different sources at the same time.
  • VESA
    VESA mount compliance means you can easily mount the LFD to any mounting that complies with the VESA standard.
iiyama ProLite LH4664S-1 46" LED display
LED-backlit LCD flat panel display
Diagonal Class
46"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Video Interface
Component, composite, HDMI, S-Video
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
AMV3
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
Remote Control
Standard remote
Voltage
Energy Class
Class B
132 Watt
Power Consumption (On mode)
94.3 W
Energy Consumption per Year
138 kWh
105.1 cm x 8.4 cm x 60.55 cm
22 kg
Energy Class
Class B
132 Watt
94.3 W
138 kWh
Diagonal Class
46"
Commercial Use
TV Tuner
No tuner
TV Tuner Presence
No
Sensors
Ambient light sensor (ALS)
Video Interface
HDMI Ports Qty
1 ports
PC Interface
HDCP Compatible
Modes
Portrait mode, landscape mode
105.1 cm
8.4 cm
60.55 cm
22 kg
Enclosure Colour
Display
LCD Display Technology
AMV3
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
LED backlight
Colour Depth
16.7 million colours
Image Contrast Ratio
4000:1
Brightness
500 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.53025 x 0.53025mm
Response Time
6.5 ms
Display Menu Language
English, German, French, Polish, Russian, Spanish, Dutch
Colour Temperature Control
Stands & Mounts
Flat Panel Mount Interface
400 x 200 mm
Remote Control
Standard remote
Audio System
Audio Controls
Sound mode, balance, bass, treble
Speaker System
2 speakers
Output Power / Total
24 Watt
Speakers
2 x speaker - built-in - 12 Watt
Connector Type
VGA input , Composite video input , S-Video input , Composite video input , Audio line-in , DVI-D input , HDMI input , DisplayPort input , Audio input , Serial output , Audio output , VGA output , Composite video output , Remote control , Serial input
VGA cable , DVI cable
DDC-2B, VESA DPMS, CB, GOST-R, TUV Bauart
Power supply
Nominal Voltage
Power Consumption Stand by
0.5 Watt
