Product
iiyama Prolite LH4281S-B1 42" DVI VGA HDMI Commercial Display
Quicklinx: CB0MWS00 Mfr#: LH4281S-B1
TV Tuner Presence: No
Video Interface: Component, HDMI
  • 1080p (Full HD)
£696.00 ex VAT
£835.20 inc VAT
The professional appearance of the ProLite LH4281S incorporates a slim design featuring a sleek bezel. Featuring IPS panel technology this elegant display ensures amazing color accuracy and vivid, life-like quality from all angles. The LED-backlit technology provides low power consumption and reliable long-term operation. Built-in expansion slot supports the Open Pluggable Specification (OPS) standard, it simplifies the installation of a plug-in PC for digital signage applications. Landscape and Portrait friendly, ProLite LH4281S is designed for a continues operation. Perfect for true impact in Digital Signage and an ideal solution for a video wall set-up.
  • IPS technology
    IPS technology offers higher contrast, darker blacks and much better viewing angles than standard TN technology. The screen will look good no matter what angle you look at it.
  • OPS PC slot
    Build-in expansion slot supports the Open Pluggable Specification (OPS) standard, it simplifies the installation of a plug-in PC for digital signage applications.
  • Ultra Slim Line
    Ultra Slim Line monitors feature a sleek bezel and are therefore particularly suitable for video wall or a multi-monitor set-up.
  • USB playback
    The monitor supports playback of presentations, video and almost any type of content stored on the USB device or internal memory.
  • LAN control
    LAN control enables making adjustments in the display OSD menu through a web interface or threads.
iiyama ProLite LH4281S-B1 42" Class (41.9" viewable) LED display
LED-backlit LCD flat panel display
Diagonal Class
42"
Diagonal Size
41.9 in
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Video Interface
Component, HDMI
HDMI Ports Qty
2 ports
PC Interface
DVI, VGA (HD-15), DisplayPort
IPS
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
USB
Remote Control
Standard remote
Voltage
Energy Class
Class C
110 Watt
Power Consumption (On mode)
11.6 W
Energy Consumption per Year
163 kWh
94.7 cm x 7.1 cm x 54.1 cm
15.3 kg
Energy Class
Class C
110 Watt
11.6 W
163 kWh
Diagonal Class
42"
Diagonal Size
41.9 in
Commercial Use
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
Component, HDMI
HDMI Ports Qty
2 ports
PC Interface
Modes
Portrait mode, landscape mode
Design
Fanless Design
94.7 cm
7.1 cm
54.1 cm
15.3 kg
Enclosure Colour
Display
LCD Display Technology
IPS
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
LED backlight
Image Contrast Ratio
1300:1
Brightness
500 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
8 ms
Display Menu Language
Czech, English, German, French, Italian, Portuguese, Polish, Russian, Spanish, Dutch, Turkish, Arabic, Japanese, Chinese
MPEG artifact reduction, Open Pluggable Specification slot, security lock slot (cable lock sold separately), Noise Reduction, remote lock
Stands & Mounts
Flat Panel Mount Interface
200 x 200 mm
Media Player
USB Port
USB Ports Qty
1
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x speaker - built-in - 10 Watt
Connector Type
2 x HDMI , 2 x DisplayPort , DVI-D input , DVI-D output , VGA input , Component video input , Audio input , Serial input , Serial output , Remote control input , Remote control output , Network , Audio input , Audio output , USB 2.0 , 2 x speakers output , Audio output
DVI cable , HDMI cable , Mini DisplayPort-DisplayPort cable , DisplayPort cable , Serial cable
DDC-2B, VESA DPMS, CB, TUV Bauart
Power supply
Nominal Voltage
Power Consumption Stand by
0.5 Watt
20 - 80% (non-condensing)
Video Interface: HDMI
Brand: iiyama
Price Range Ex VAT: 500 - 750
