iiyama ProLite LH4265S 42" 1920x1080 6.5ms VGA HDMI RCA AV LED LFD
Quicklinx: CW6CWS00 Mfr#: LH4265S-B1
  • 1080p (Full HD)
ProLite LH4265S is a 42'' Full HD, professional and fan-less LED-backlit display. Incorporating AMVA3 panel technology, the display guarantees great viewing from all angles, high brightness and exceptional color clarity. It features an ambient light sensor delivering exceptional performance with the added benefit of saving on power. A wide range of video and audio inputs ensures compatibility with multiple platforms. Landscape and portrait friendly, ProLite LH4265S is prepared for easy installation using the VESA wall mount and daisy chain support. A perfect solution for a massive range of applications including public signage, retail, exhibitions and conference centers, POS/POI, control rooms and production facilities.
  • AMVA3 technology
    AMVA3 technology offers higher contrast, darker blacks and much better viewing angles than standard TN technology. The screen will look good no matter what angle you look at it.
  • USB playback
    The monitor supports playback of presentations, video and almost any type of content stored on the USB device or internal memory.
  • Light sensor
    The ambient light sensor detects changes in environmental lighting conditions and automatically adjusts the screens backlight brightness to compensate for an increase or decrease in light.
  • LAN control
    LAN control enables making adjustments in the display OSD menu through a web interface.
iiyama ProLite LH4265S-B1 42" LED display
LED-backlit LCD flat panel display
Diagonal Class
42"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Video Interface
Component, composite, HDMI
HDMI Ports Qty
3 ports
PC Interface
VGA (HD-15)
AMVA3
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
Remote Control
Standard remote
Voltage
Energy Class
Class B
72 Watt
Power Consumption (On mode)
72.2 W
Power Consumption Stand by
0.5 Watt
Energy Consumption per Year
105 kWh
96.05 cm x 5.75 cm x 55.35 cm
18.4 kg
Energy Class
Class B
72 Watt
72.2 W
105 kWh
Diagonal Class
42"
Commercial Use
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
HDMI Ports Qty
3 ports
PC Interface
VGA (HD-15)
96.05 cm
5.75 cm
55.35 cm
18.4 kg
Enclosure Colour
Display
LCD Display Technology
AMVA3
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
LED backlight
Image Contrast Ratio
3000:1
Brightness
400 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
6.5 ms
Display Menu Language
Czech, English, German, French, Polish, Russian, Dutch, Japanese
Stands & Mounts
VESA Mounting Interface
400 x 400 mm
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x speaker - built-in - 10 Watt
Connector Type
VGA input , 3 x HDMI input , Component video input , Composite video input , Audio line-in , Audio input , Audio output , Serial input , Serial output , Network , Composite video output , Infrared input , Infrared output , Speakers output , 2 x USB 2.0
Cable ties, batteries, logo sticker
VGA cable , HDMI cable
VESA DPMS, CB, TUV Bauart, CU
Power supply
Nominal Voltage
0.5 Watt
