Incorporating IPS panel technology the LH4264S guarantees great viewing from all angles, high brightness and exceptional color clarity. It features an ambient light sensor delivering exceptional performance with the added benefit of saving on power. Features include PIP and PBP perfect for video conferencing or handing multi-input content in many environments. Landscape and portrait friendly, the display can be mounted according to the application for true impact in digital signage.
- Iiyama ProLite LH4264S-1 42" LED display
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 42"
- Commercial Use
- Yes - digital signage
- Black
- Resolution
- 1920 x 1080
- Display Format
- 1080p (Full HD)
- Video Interface
- Component, composite, HDMI, S-Video
- HDMI Ports Qty
- 1 ports
- PC Interface
- DVI, VGA (HD-15), DisplayPort
- HDCP Compatible
- Technology
- IPS
- LCD Backlight Technology
- LED backlight
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Speaker System
- 2 speakers
- Remote Control
- Standard remote
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class C
- 119 Watt
- Power Consumption (On mode)
- 100 W
- Energy Consumption per Year
- 146 kWh
- 98.05 cm x 10.5 cm x 57 cm
- 18 kg
- Product Type
- Energy Class
- Class C
- 119 Watt
- 100 W
- 146 kWh
- Diagonal Class
- 42"
- Commercial Use
- TV Tuner
- No tuner
- Sensors
- Ambient light sensor (ALS)
- Video Interface
- HDMI Ports Qty
- 1 ports
- PC Interface
- HDCP Compatible
- Modes
- Portrait mode, landscape mode
- 98.05 cm
- 10.5 cm
- 57 cm
- 18 kg
- Enclosure Colour
- Black
Display
- LCD Display Technology
- IPS
- Resolution
- 1920 x 1080
- Display Format
- 1080p (Full HD)
- 16:9
- LED backlight
- Colour Depth
- 16.7 million colours
- Image Contrast Ratio
- 1000:1
- Brightness
- 400 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Pixel Pitch
- 0.4833mm x 0.4833mm
- Response Time
- 9 ms
- Display Menu Language
- English, German, French, Polish, Russian, Spanish, Dutch
- Colour Temperature Control
Stands & Mounts
- Flat Panel Mount Interface
- 400 x 200 mm
Remote Control
- Standard remote
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 24 Watt
- Speakers
- 2 x speaker - built-in - 12 Watt
- Connector Type
- VGA input , Component video input , S-Video input , Composite video input , Audio line-in , DVI-D input , HDMI input , DisplayPort input , Audio input , Serial output , Audio output , VGA output , Composite video output , Network , Serial input , Speakers output
- Cables Included
- VGA cable , DVI cable
- DDC-2B, VESA DPMS, CB, TUV Bauart
- Power Device
- Power supply
- Nominal Voltage
- Power Consumption Stand by
- 0.5 Watt
