iiyama ProLite LE5040UHS-B1 50" 3840x2160 8ms VGA DVI HDMI LED Large Format Display
Quicklinx: F4DXWS00 Mfr#: LE5040UHS-B1
TV Tuner Presence: No
Video Interface: HDMI
Hurry, only 3 left in stock!
£502.35 ex VAT
£602.82 inc VAT
See the difference with the ProLite LE5040UHS, a professional digital signage display with 4K graphics, 18/7 operating time and landscape orientation. Featuring a slim bezel and an AMVA3 LED panel for exceptional color and image performance and iiSignage, iiyama's free signage content creation and management software, the LE5040UHS offers businesses an easy and effective solution to help capture their audience's attention.
  • UHD resolution
    UHD resolution (3840x2160), better known as 4K, offers a gigantic viewable area with 4 times more information and work space than a Full HD screen. Due to the high DPI (dots per inch), it displays an incredibly sharp and crisp image.
  • AMVA3 technology
    AMVA3 technology offers higher contrast, darker blacks and much better viewing angles than standard TN technology. The screen will look good no matter what angle you look at it.
  • iiSignage
    With iiSignage, you can easily create, publish and manage your own digital signage content on any iiyama 40-series display from a desktop PC in the same network. Use rich content like video's and widgets to create highly impactful advertising in minutes and schedule your content across multiple displays to best match your customers' behavior.
iiyama ProLite LE5040UHS-B1 50" LED display - 4K
LED-backlit LCD flat panel display
Diagonal Class
50"
Commercial Use
Yes - digital signage
Matte black
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Video Interface
HDMI
HDMI Ports Qty
2 ports
LAN
PC Interface
DVI, VGA (HD-15)
AMVA3
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
Supported Memory Cards
microSD
USB
2 ports
Remote control, batteries
Voltage
Energy Class
Class B
140 Watt
Power Consumption (On mode)
125.4 W
Power Consumption Stand by
0.5 Watt
Energy Consumption per Year
183 kWh
112.35 cm x 6.8 cm x 64.65 cm
12.6 kg
Energy Class
Class B
140 Watt
125.4 W
183 kWh
Diagonal Class
50"
Commercial Use
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
HDMI
HDMI Ports Qty
2 ports
PC Interface
DVI, VGA (HD-15)
Modes
Landscape mode
Design
Thin Bezel Design
Cooling System
Fanless
Dimensions
Without stand
112.35 cm
6.8 cm
64.65 cm
12.6 kg
Enclosure Colour
Matte black
Display
LCD Display Technology
AMVA3
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Image Aspect Ratio
16:9
LED backlight
Image Contrast Ratio
4000:1
Brightness
350 cd/m²
Viewing Angle
178°
Viewing Angle (Vertical)
178°
Response Time
8 ms
Display Menu Language
Czech, English, German, French, Italian, Polish, Russian, Spanish, Dutch, Japanese, Chinese
Operation Hours / Days
18 / 7
Anti Image Retention Circuitry (AIR), Iiyama iiSignage preinstalled
Stands & Mounts
Flat Panel Mount Interface
400 x 400 mm
Media Player
microSD
USB Port
USB Ports Qty
2
Operating System
Android OS
Remote Control
Remote control
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - 10 Watt
Network & Internet Multimedia
Functionality
Streaming media playback
LAN
Connector Type
VGA input , 2 x HDMI input , DVI-D input , Audio input , Serial input , LAN , Infrared input , Audio output , Infrared output , USB 2.0 , USB 3.0
Batteries
DVI cable , HDMI cable , Serial cable
Plug and Play, DDC-2B, CB, TUV Bauart, CU
Power supply
Nominal Voltage
0.5 Watt
Brand: iiyama
Price Range Ex VAT: 500 - 750
