iiyama Prolite LE4340S-B1 43" 8ms VGA DVI HDMI USB LCD Display
Installation required? Contact us today!
Quicklinx: CB0HWS00 Mfr#: LE4340S-B1
  • 1080p (Full HD)
ProLite LE4340S is a 43" Full HD, professional and fan-less LED-backlit display. Incorporating the latest Commercial Grade AMVA panel technology, the display guarantees great viewing from all angles, high brightness and exceptional color clarity. A wide range of video and audio inputs ensures compatibility with multiple platforms. ProLite LE4340S is prepared for easy installation using the VESA wall mount.
  • USB playback
    The monitor supports playback of presentations, video and almost any type of content stored on the USB device or internal memory.
  • AMVA3
    AMVA3 technology offers higher contrast, darker blacks and much better viewing angles than standard TN technology. The screen will look good no matter what angle you look at it.
  • Full HD
    With true 1920 x 1080p resolution your monitor is ready to display high definition images. This means you can accommodate more information on your screen; 60% more in comparison to a 1280 x 1024 monitor.
  • VESA
    VESA mount compliance means you can easily mount the LFD to any mounting that complies with the VESA standard.
iiyama ProLite LE4340S-B1 43" LED display
LED-backlit LCD flat panel display
Diagonal Class
43"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Video Interface
Component, HDMI
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
AMV3
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Picture Enhancements
Pixel Shift
Speaker System
2 speakers
USB
Remote Control
Standard remote
Voltage
AC 100/240 V (50/60 Hz)
Energy Class
Class B
73 Watt
96.68 cm x 6.1 cm x 55.95 cm
8.7 kg
Energy Class
Class B
73 Watt
Diagonal Class
43"
Commercial Use
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
Component, HDMI
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
Modes
Landscape mode, Eco mode
Pixel Shift
Timer Functions
Sleep
Dimensions
Without stand
96.68 cm
6.1 cm
55.95 cm
8.7 kg
Enclosure Colour
Display
LCD Display Technology
AMV3
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
LED backlight
Colour Depth
16.7 million colours
Image Contrast Ratio
3000:1
Brightness
350 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.49 x 0.49mm
Response Time
8 ms
Display Menu Language
Czech, English, German, French, Italian, Polish, Russian, Spanish, Dutch
Stands & Mounts
VESA Mounting Interface
200 x 200 mm, 400 x 400 mm
Media Player
USB Port
USB Ports Qty
1
Remote Control
Standard remote
Audio System
Audio Controls
Sound mode, bass, treble
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - built-in - 10 Watt
Connector Type
HDMI input , DVI-D input , VGA input , Component video input , Audio line-in , Audio line-in , Audio line-out , Serial input , Serial output , Remote control input , Remote control output , Network , USB 2.0
VGA cable , DVI cable , Serial cable
DDC-2B, VESA DPMS, CB, TUV Bauart
Power supply
Nominal Voltage
On / Off Switch
Auto On/Off
WOL (Wake on LAN)
