iiyama ProLite E2483HS-B3 24" Full HD, Black, HDMI, Display Port
Quicklinx: D3Q7WS00 Mfr#: E2483HS-B3
Diagonal Size: 24in
Max Resolution: 1920 x 1080
Response Time: 1ms
Speakers: Speaker(s)
Interfaces: DisplayPort, HDMI, VGA (HD-15)
More than 50 in stock
£99.16 ex VAT
£118.99 inc VAT
The ProLite E2483HS is an excellent 24" Full HD LED-backlit monitor with 1920 x 1080p resolution. It features short response time and advanced contrast ratio, assuring clear and vibrant picture quality and high contrast. Triple input support ensures compatibility with the installed graphics cards and embedded notebook outputs. The E2483HS is also equipped with two high-quality stereo speakers. This monitor is a reliable solution for both home and office use.
  • Flicker-free and blue light
    The ultimate solution for the comfort and health of your eyes. Flicker-free monitors with blue light reducer function. Absolutely no flickering. And the amount of blue light, emitted by the screen and responsible for your eyes feeling fatigued, substantially reduced.
  • Speakers and headphones
    Playing with friends? Use the integrated high-quality speakers. Don't want to disturb anybody? Plug your headset to the headphone socket and turn the volume up.
  • OverDrive on/off
    When very fast graphics are displayed, your monitor can sometimes get blurry. Turning on the OverDrive feature will eliminate that.
  • ACR
    Advanced contrast ratio is a feature, that automatically adjusts contrast and brightness of the screen to assure perfect picture quality, while watching films and playing games.
  • Full HD
    With true 1920 x 1080p resolution your monitor is ready to display high-definition images. This means you can accommodate more information on your screen.
iiyama ProLite E2483HS-B3 - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class A
Energy Consumption per Year
36 kWh
Power Consumption (On mode)
24.9 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.277 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 80000000:1 (dynamic)
Response Time
1 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Tilt
Screen Coating
Matte
56.55 cm x 20.3 cm x 41.2 cm
3.4 kg
Environmental Standards
ENERGY STAR Qualified
TUV GS, DDC-2B, VESA DPMS, PSE Mark, VCCI Class B, CU
Display Type
Energy Class
Class A
36 kWh
24.9 W
Diagonal Size
24"
Viewable Size
24"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.277 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
1 ms
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
+85 / -85
Vertical Viewing Angle
+80 / -80
Screen Coating
Matte
Backlight Technology
LED backlight
OSD Languages
Czech, English, German, French, Italian, Polish, Russian, Spanish, Dutch, Japanese, Chinese
HDCP, Overdrive technology, Advanced Contrast Ratio (ACR), Flicker Free technology, blue light reduction
3.4 kg
Audio
Speakers - stereo
Output Power / Channel
1 Watt
VGA , DisplayPort , HDMI , Headphones , Audio line-in
Mechanical
Tilt
Tilt Angle
-5/+22
VESA Mounting Interface
100 x 100 mm
1 x HDMI cable , 1 x audio cable
24 Watt
Power Consumption Stand by
0.5 Watt
Included Software
Driver
ENERGY STAR Certified
iiyama ProLite E2483HS-B3 24 Bundle deal on iiyama ProLite E2483HS-B3 24" Full HD, Black, HDMI, Display Port
£198.33
Diagonal Size: 24in
Response Time: 1ms
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: iiyama
Price Range Ex VAT: 50 - 100
